Hello All,
I am trying to use the xdata of the Atmel 89C51RD2 chip but it seems not to be working. I have tried most of all the suggestion I search on this forum but non seems to work. There is definitely something I am not getting write.
Here is all I have done thus far
1. Changing the Start up code as follows
IDATALEN EQU 100H XDATASTART EQU 00H XDATALEN EQU 700H ; 1792 size PDATASTART EQU 0H PDATALEN EQU 0H ; Standard SFR Symbols ACC DATA 0E0H B DATA 0F0H SP DATA 81H DPL DATA 82H DPH DATA 83H AUXR DATA 8EH ; add SFR definition for AT89c51xD2 STARTUP1: ; enable on-chip xdata RAM for AT89c51xD2 MCU's ANL AUXR,#10H ;AUXR/Bit 1(clear to 0 to enable on-chip XRAM and set address 1792)
2. On the option for target window, I also checked the "Use On-Chip ROM" , "Use On-Chip XRAM" & "use multiple DPTRs registers".
3. I declead most of my data's with xdata. For example
void MUL (u8 *val_1,u8 *val_2) { u8_X R_val = 0xE1; u8 xdata V_val[16]; u8_X mask_b = 0x80; u16_X i; u8_X j; bit chk=0; ........ ........
I intend to declare most of my variable into Xdata, which I did, but I still have a lot of Address space overflow. How can I fix the issue. I am of the thought that there should still be space in Data since I am storing much variables into it, especially large arrays.
I checked the Data memory in the Map file to trace out where the excess might be. I found out that the size of the Xdata and Code in a given function matches the value in the mapfile. But for the data memory, I see some increase in the size, and I can possible find how that increase came about, afterall, I did not declear any variable in the data memory in the function.
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: ?DT?_INV_?CIPHER LENGTH: 0006H *** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: ?DT?_MUL_?ENCRYPT LENGTH: 0006H
Has anyone experience this before?
How do you imagine you can know that, given that your program doesn't even link?
That comment doesn't match what the code actually does.
That conclusion is incorrect. Just because you moved a lot of stuff out of DATA does not automatically mean there will now be sufficient space for the remaining stuff. A lot is not necessarily enough.
It's not exactly easy to understand what you're trying to say there. But it does sound like you have to get back to the documentation and read up on how Keil's compiler and linker for the '51 handle automatic variables. Have you heard about "data overlaying"?
