header file not found, Showing Error
i am working on a project for the automatic power reading using gsm
but getting some errors:
please check the program and guide me
Build target 'Target 1'
compiling codec.c...
codec.c(2): warning C318: can't open file 'lcd.h'
codec.c(3): warning C318: can't open file 'rtc.h'
codec.c(5): warning C318: can't open file 'bcd2ascii.h'
codec.c(6): warning C318: can't open file 'serial.h'
CODEC.C(35): warning C206: 'lcdInit': missing function-prototype
CODEC.C(36): warning C206: 'LCDstr': missing function-prototype
CODEC.C(36): error C267: 'LCDstr': requires ANSI-style prototype
Target not created
#include<reg52.h>
#include <lcd.h>
#include <rtc.h>
#include<string.h>
#include<bcd2ascii.h>
#include<serial.h>
sbit sw1=P3^7;
sbit sw2=P3^6;
sbit sw3=P3^5;
sbit buzzer=P2^3;
sbit relay=P2^2;
sbit rled =P3^4;
sbit gled =P3^3;
bit flag_sw,flagr=0;
static unsigned char k=0,s=0x84,*result,h,unit=0;
unsigned char inc=23,check_flag=0,month_flag=0,month;
unsigned char *time,*res;
unsigned char idata byte1[100];
unsigned char *date,*u,i,j,a=0,b,c,d;
void main()
{ TMOD=0x20; // serial communication intialization
TH1=0XFD;SCON=0X50;TR1=1;i=0;
IE=0X91;IT0=0;
lcdInit(); // LCD intialization
LCDstr("AUTOMATIC POWER",0x80);
LCDstr("METER READING",0xc0);
delay(2000);
gsm_check();gsm_rec(); //gsm modem intialization
gled=0;rled=1;buzzer=1;relay=1;
while(1) //super loop
//time display
LCDstr("DATE ",0x80);
LCDstr("TIME",0xc0);
date=getDate();
LCDstr(date,0x86);
time=getTime();
LCDstr(time,0xc6);
flag_sw=0;delay(1000);
//units display
putComL(0x01);
LCDstr("UNITS=",0x80);
putComL(0x86);
unit=getCharE(0x15);
u=bcdtoascii(unit);
LCDstr(u,0x87);
delay(2000);
/**************checking********************/
a=getCharE(0x04); // gsm modem sending sms
if(a>=28 )
{ gsm_check();
delay(200);
ES=0;
unit=0;
putCharE(unit,0x15);
rled=0;gled=1;
gsm_send(byte,"number"); }
//else case
if(a>=16 & d==c){month_flag=1;}
else month_flag=0;month_flag=getCharE(0x20);
if(check_flag==0 & month_flag==1 &flagr==0){flagr=1;relay=0;rled=0;gled=1;buzzer=0;delay(100);buzzer=1;}
else if(check_flag==1 ){ gled=0;rled=1;buzzer=1;relay=1;} delay(1000);
//receving sms
for(j=0;j<100;j++) {if(byte1[j]=='*' &byte1[j+1]=='P' & byte1[j+2]=='A'& byte1[j+3]=='I'& byte1[j+4]=='D') {ES=0;LCDstr("received",0xc0); a=1;check_flag=1;putCharE(check_flag,0x10); gsm_rec(); }} //time setting
if(sw3==0){enter_time();}
delay(1000);k=0;
Please Guide Me...
0
