Hi all
How exactly an analog mode A/D input is simulated in the KEIL for ARM compiler while it works in analog mode ?
Thanks Elico
u put the wire near to keybrd? it detect the amperage.
What ????????????
Ignore the stupid troll's reply. You need to look into the Debugger's Virtual registers and write a script to emulate your analog input. There are several examples at this website. Look at the example below for the C51/C166 devices. Also, look at your debugger manual to see how to write the scripts for the emulation.
I don't have ARM tools installed on this computer so it's not easy for me to look at the example code but I'm sure there is an ADC example in the Examples folder or the Boards folder of your tool set.
http://www.keil.com/support/docs/1942.htm
Bradford
Many thanks I get the picture .
Elico
