LPC2468 timer interrupt
Hi guys
I am going through a very strange problem, I made a code which comes in timer interrupt after certain period of time but even after correct configuration of all registers the code is not coming in ISR even in the simulator. But in simulator it is observed that the interrupt flag is setting. Follwoing is the sorce code
 __irq void T2_IRQHandler (void) //x milli second timer
    T2IR        = 1; // Clear interrupt flag
    VICVectAddr = 0; // Acknowledge Interrupt
void inittimer()
PCONP             |=(1<<22);
T2MR0          = 14999;
T2MCR          = 3;                           // Interrupt and Reset on MR0
T2PR          = 9;                      //prescale register     for 10 millisec
VICVectAddr26  = (unsigned long)T2_IRQHandler;// Set Interrupt Vector
VICVectCntl26  = 14;                          // use it for Timer0 Interrupt
VICIntEnable  = (1  << 26);                   // Enable Timer0 Interrupt
T2TCR         = 1;                           // Timer0 Enable
Please help me out
Thanx in advance
  • Timer 2 is not powered by default. Maybe the timer is not running...?
  • Hi
    Thanx for the reply
    I have powered up the timer by setting PCONP and yet i am able to see that the timer is running in simulator
  • This code works fine in simulation so I wonder what you are doing wrong.
    #include <lpc24xx.h>
                    void inittimer()
    PCONP             |=(1<<22);
    T2MR0          = 14999;
    VICVectPriority26  = 14;                          // set priority to 14
    void main(void){
            inittimer();
            while(1);
    Note the VICVectCntl does not exist in 23xx/24xx devices (check the user manual)so I would suggest you start using the existing register which is VICVectPriority which is the interrupt priority, default priority is 15 (lowest) to 0 (highest).
    The header file is wrong to have the VICVectCntl register (which actually points to the VICVectPriority address) since this register was used differently
    Alex
