Xdata Variables not accessable
Dear Experts,
I am a newbie to Keil and using the PK51 development kit with Rev:9.03 to develop firmware for my CC2430 controller.
The problem I am seeing is, when ever I create a large array (ex: unsigned char a[20]) , I was unable to initialize the values in the array. I can see the array has been created in XDATA. However if I create unsigned char IDATA a[20], I was able to initialize the array.
One more observation is, after executing the code for a couple of seconds (not exactly), the execution was looping in the following lines of code (STARTUP.A51).
XDATALOOP: MOVX @DPTR,A INC DPTR DJNZ R7,XDATALOOP DJNZ R6,XDATALOOP
The XDATA initialization as per my startup code is
XDATASTART EQU 0x0100
XDATALEN EQU 0x1000
Can anyone let me know whats happening in my code. Please let me know, if any additional information is required to analyze the situation.
Also, Please forward me any available CC2430 Keil project.
Thanks in advance,
Regards,
RD
  • XDATASTART EQU 0x0100
    why not 0?
    why post unreadable, why initailize 64k when you only have 8, the time sounds right
  • Thanks for the help.
    Here is the modified STARTUP.A51, with which the code hangs after executing a couple of functions. I am sorry for asking to analyze the whole file.
    -RD
    $NOMOD51
    STACKSIZE   EQU 0x85                    ; must not exceed IDATA SEG
    ;  User-defined <h> Power-On Initialization of Memory
    ;  With the following EQU statements the initialization of memory
    ;  at processor reset can be defined:
    ; <o> IDATALEN: IDATA memory size <0x0-0x100>
    ;      Note: The absolute start-address of IDATA memory is always 0
    ;            The IDATA space overlaps physically the DATA and BIT areas.
    IDATALEN        EQU     0 ;080H
    ; <o> XDATASTART: XDATA memory start address <0x0100-0xFFFF>
    ;      The absolute start address of XDATA memory
    ;XDATASTART      EQU     0x0100
    XDATASTART      EQU     0x0
    ; <o> XDATALEN: XDATA memory size <0xE000-0xFD55>
    ;      The length of XDATA memory in bytes.
    ;XDATALEN        EQU     0x1000
    XDATALEN        EQU     0x0
    ; <o> PDATASTART: PDATA memory start address <0x0-0xFFFF>
    ;      The absolute start address of PDATA memory
    PDATASTART      EQU     0x00
    ; <o> PDATALEN: PDATA memory size <0x0-0xFF>
    ;      The length of PDATA memory in bytes.
    PDATALEN        EQU     0H
    ;</h>
    ;<h> Reentrant Stack Initialization
    ;  The following EQU statements define the stack pointer for reentrant
    ;  functions and initialized it:
    ; <h> Stack Space for reentrant functions in the SMALL model.
    ;  <q> IBPSTACK: Enable SMALL model reentrant stack
    ;      Stack space for reentrant functions in the SMALL model.
    IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
    ;  <o> IBPSTACKTOP: End address of SMALL model stack <0x0-0xFF>
    ;      Set the top of the stack to the highest location.
    IBPSTACKTOP     EQU     0xFF +1     ; default 0FFH+1
    ; </h>
    ; <h> Stack Space for reentrant functions in the LARGE model.
    ;  <q> XBPSTACK: Enable LARGE model reentrant stack
    ;      Stack space for reentrant functions in the LARGE model.
    XBPSTACK        EQU     1       ; set to 1 if large reentrant is used.
    ;  <o> XBPSTACKTOP: End address of LARGE model stack <0x0-0xFFFF>
    XBPSTACKTOP     EQU     0x1EFF +1 ; 0x1EFF +1
    ; </h>
    ; <h> Stack Space for reentrant functions in the COMPACT model.
    ;  <q> PBPSTACK: Enable COMPACT model reentrant stack
    ;      Stack space for reentrant functions in the COMPACT model.
    PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
    ;   <o> PBPSTACKTOP: End address of COMPACT model stack <0x0-0xFFFF>
    PBPSTACKTOP     EQU     0xFF +1     ; default 0FFH+1
    ; </h>
    ;</h>
    ;  Memory Page for Using the Compact Model with 64 KByte xdata RAM
    ;  <e>Compact Model Page Definition
    ;  Define the XDATA page used for PDATA variables.
    ;  PPAGE must conform with the PPAGE set in the linker invocation.
    ; Enable pdata memory page initalization
    PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
    ; <o> PPAGE number <0x0-0xFF>
    ;  uppermost 256-byte address of the page used for PDATA variables.
    PPAGE           EQU     0
    ; <o> SFR address which supplies uppermost address byte <0x0-0xFF>
    ;  most 8051 variants use P2 as uppermost address byte
    PPAGE_SFR       DATA    0A0H
    ; </e>
    ; Standard SFR Symbols
    ACC     DATA    0E0H
    B       DATA    0F0H
    SP      DATA    81H
    DPL0    DATA    82H
    DPH0    DATA    83H
    DPL1    DATA    84H
    DPH1    DATA    85H
    DPS     DATA    92H
                    NAME    ?C_STARTUP
    ?C_C51STARTUP   SEGMENT   CODE
    ?STACK                                 SEGMENT   IDATA
        RSEG     ?STACK
        DS           STACKSIZE
                    EXTRN CODE (?C_START)
                    PUBLIC  ?C_STARTUP
                    CSEG    AT      0
    ?C_STARTUP:     LJMP    STARTUP1
                    RSEG    ?C_C51STARTUP
    STARTUP1:
    IF IDATALEN <> 0
                    MOV     R0,#IDATALEN - 1
                    CLR     A
    IDATALOOP:      MOV     @R0,A
                    DJNZ    R0,IDATALOOP
    ENDIF
    IF XDATALEN <> 0
                    MOV     DPTR,#XDATASTART
                    MOV     R7,#LOW (XDATALEN)
      IF (LOW (XDATALEN)) <> 0
                    MOV     R6,#(HIGH (XDATALEN)) +1
      ELSE
                    MOV     R6,#HIGH (XDATALEN)
      ENDIF
                    CLR     A
                    INC     DPTR
                    DJNZ    R7,XDATALOOP
                    DJNZ    R6,XDATALOOP
    ENDIF
    IF PPAGEENABLE <> 0
                    MOV     PPAGE_SFR,#PPAGE
    ENDIF
    IF PDATALEN <> 0
                    MOV     R0,#LOW (PDATASTART)
                    MOV     R7,#LOW (PDATALEN)
                    CLR     A
    PDATALOOP:      MOVX    @R0,A
                    INC     R0
                    DJNZ    R7,PDATALOOP
    ENDIF
    IF IBPSTACK <> 0
    EXTRN DATA (?C_IBP)
                    MOV     ?C_IBP,#LOW IBPSTACKTOP
    ENDIF
    IF XBPSTACK <> 0
    EXTRN DATA (?C_XBP)
                    MOV     ?C_XBP,#HIGH XBPSTACKTOP
                    MOV     ?C_XBP+1,#LOW XBPSTACKTOP
    ENDIF
    IF PBPSTACK <> 0
    EXTRN DATA (?C_PBP)
                    MOV     ?C_PBP,#LOW PBPSTACKTOP
    ENDIF
                    MOV     SP,#?STACK-1
    ; This code is required if you use L51_BANK.A51 with Banking Mode 4
    ;<h> Code Banking
    ; <q> Select Bank 0 for L51_BANK.A51 Mode 4
    #if 0
    ;      Initialize bank mechanism to code bank 0 when using L51_BANK.A51 with Banking Mode 4.
    EXTRN CODE (?B_SWITCH0)
                    CALL    ?B_SWITCH0      ; init bank mechanism to code bank 0
    #endif
    ;</h>
                    LJMP    ?C_START
                    END
  • Hi,
    Is this problems solved? I encounter the same problem. When XDATALEN < 256 bytes it works fine.
    Larger values restart the code @ address 0x0000.
    Thanks,
    Rob
  • Does your particular chip actually have > 256 bytes XRAM?
    Have you correctly configured and/or enabled it?
    See the chip datasheet for specific details, SFRs, etc,...
  • Yes, the chip (Silabs C8051F920) has XRAM of 4096 bytes in the range of 0x0000 - 0x0FFF
    As far as i found out there is nothing special to do related to SFR to access the full 4K.
  • Have you used the on-chip debug to step through and see where, exactly, it fails?
  • In the meantime i have tested with single stepping and discovered that it goes wrong when the DPTR reaches 0x00EA. executing MOVX @DPTR,A with a DPTR of 0x00EA restarts the MCU.. I assume this is a question for Silicon Labs.
  • the ever repeated issue with SILabs deviates (f3x-up) is that the watchdog is enabled at reset. The startup code does not feed the dog, so it bites.
    at the start of startup.a51 (prefererably a local copy) disable the watchdog and enable it asgain at th top of main.
  • My phobia for dogs has always play a big role in my life ;-)
    Thanks !!
