Environment uVision4, Windows 7, 64 bit. RTOS is uC/OS-iii. Assembly language. A file named cpu_a.asm is copied in from an IAR environment. Some critical lines are:
PUBLIC CPU_IntDis ... RSEG CODE:CODE:NOROOT(2) ... CPU_IntDis
For the first I think PUBLIC should change to EXPORT: EXPORT CPU_IntDis Is this correct?
For the second the error is: error: A1163E: Unknown opcode RSEG , expecting opcode or Macro
I can find some things about RSEG but cannot determine what is intended by the entire line. How must this line be changed?
For the third the error is: error: A1355U: A Label was found which was in no AREA
I have not discovered the full significance of this error. How should this be changed?
