if i am not using position independent options while using rtx will it make my application thread unsafe?
i am asking because standard library functions are by default non re entrant
And what do you think does that have to do with position-independent code? Or RTOS, for that matter?
excuse me if i asked something wrong!! i am new to this one. all i wanted to know is if i make my code position-independent will it make standard library functions re-entrant or not?
don't confuse when i say "my code" or "application" actually i am talking about R/W section
By making standard library functions re-entrant i can use them in RTOS safely. So if library functions are by default non-re-entrant how can i make them re-entrant?
And what other things that i have to consider when i use RTX?
You can't make non-reentrant library functions whatever you do.
Making them movable doesn't change their reentrant capabilities.
So when calling a non-reentrant function, you must make sure that no other thread tries to perform other calls at the same time. And a function in a library may call other functions in the library, so even two different function calls may be forbidden to call concurrently because they call a common, non-reentrant function.
