I want to automate our build proceedure (using CruiseControl). Unfortunately our ancient version of uVision (2.14) seems not to be able to output a makefile. Is it possible to run uVision from a batch file such that it builds the target and exits?
yes
you can not run uVision from a .bat file, but you can run the assembler, compiler and linker from a .bat file and achieve your build
You've been better at checking your facts, Erik. Actually uVision can quite usefully be run from batch files. And unless memory fails me spectacularly, even version 2 could.
... and its manual told you how.
http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm
That's the uVision-4 manual - not sure that uVision-2 is identical here...
Thanks everyone. The command line as described in the V4 manual works for uVision 2 - at least for the options I needed.
Please enlighten us: what is the insurmountable obstacle keeping you from just using the manual of the version you actually have, which is installed right there on your local machine?
