Hello everyone,
It is the first time I post here, so hello everyone, I hope someone of you can help me. I have been using C51 (9.03) compiler and BL51 linker till now. But now the problem with the code size arrive. In order to save code I tried to use LX51(V4.55a) linker (code paking) and here is when the problem arrives.
When using the BL51 linker I had the following directive in BL51 Misc-Misc controls: CODE (?pr?*?ISPFUNCTION(0xF800)). I need the code of this module on that address, but now, when using the LX51 linker (using the same directive in LX51 Misc-Misc controls) and with the code packing feature active the following error arrives:
*** ERROR L247: I/O ERROR ON FILE: EXCEPTION 0029H: ACCESS TO FILE DENIED FILE: ?pr?*?ISPFUNCTION(0xF800) Target not created
Could you please tell me why? Should I use the directive in another way in order to place that modulo in that address. I have checked the LX51 manual and I do not find any clue about this problem.
Thank you very much in advance.
It sounds extrange since using the same directive with LX51 without activating code packing does not output any error. Before posting I looked for an equivalent directive for LX51 without success. I saw the same directive (same structure and meaning)for LX51 in a PDF and then a CODE directive (online documentation)without params that activates an output code file. Could someone give me a clue? I am quite lost now.
Thank you very much.
