E-Eval STM32 F103ZGT6
We have a problem with standard working ST firmware that won’t compile on Keil for E-Eval directive.
The firmware is made for the board, is supposed to run out of the box, and indeed does compile on other toolchains for E-Eval.
It would be useful at this point to have Keil debugging working with this code.
It is the Virtual Com Port sub-project from the following:
www.st.com/.../um0424.zip
I find that the Virtual Com Port project will not compile on Keil for E-Eval option, although it will compile on Keil for the others (B-eval, C-eval, E_XL etc).
What is very strange is that the error messages I get relate to files common across all the other sub-projects, yet other sub-projects in the above will compile for E-Eval.
Others in the firm, on different machines, also experience this error.
Any ideas ?
