Files open in Read Only in uVision 3
I just re-installed uVision 3 and then tried to open an old project. The project is about 500 bytes of compiled code. However, it will only open the files in read only mode - there is a yellow key next to them. I looked on the knowledge base - only info is that if files are bigger than the eval version allows, then they will be read only - not the case in my situation. Any ideas?
0
