LCD Interfacing
I am trying to print characters on the LCD. I am stuck in setting the DDRAM Address. I know that we must use the SET DD RAM Address instruction. Does this address specify the start of the DDRAM address? Does this have to start above 0x40000000 (Start of RAM in Memory Map) ? Also, how can we specify an 8-bit address if we can only specify 7 bits in the instruction?
