hi. i got a problem in compiling this program.can anyone help me???i tried so many times..but still got error..can anyone help me what is wrong and what to be change.tq.here,is the program:
#include<reg51.h> #include <intrins.h> #include"lcdbusy.h"
#define tensec 150 void ext_init(void); void timerinterrupt_init(); // calling the timer and exter interrupt init functions void timer0_init();
void delay(unsigned int ); void start_poring(void); //////////////////*****************************************************//////////// sbit sw1=P2^0; // assign the p2.0 for switch0 sbit sw2=P2^1; // assign the p2.1 for switch1
sbit MOT_FWD=P0^0; sbit MOT_REV=P0^1;
/////////////////////*****************************************************//////// bit counterflag=0;
volatile bit solaniodflag=0,timer_flag=0; unsigned char val=0,location=0; volatile unsigned int count_ON=0; /*******************************************************************************************/ void main() { timer0_init(); ext_init(); lcd_init(); message(0x80,"INJUCTION PUMP"); message(0xc0,"sw1 10ml, sw2 15ml"); delay(50); while(1) { if(sw1==0) { for(val=0;val<5;val++) { MOT_FWD=0; delay(2); MOT_REV=1; } }
if(sw2==0) { for(val=0;val<10;val++) { MOT_FWD=0; delay(2); MOT_REV=1; } break; } if(solaniodflag==1) { ET0=1; // enable the timer interrupt flag bit in the IE register TR0=1; //Start the Timer solaniodflag=0; // clearing the interrupt flag bit timer_flag=1; start_poring(); } if(timer_flag==1) { while(1) { start_poring(); if(count_ON>=tensec) { TR0=0; //Timer OFF ET0=0; // Disable the timer interrupt timer_flag=0; count_ON=0; P0=0x00; break; } } } } }
void timer0_init(void) { TL0=0XFD; TH0=0X4B; // timer registewr value for 50 msec }
void timer0(void) interrupt 1 { TR0=0; TL0=0XFD; TH0=0X4B; TR0=1; count_ON++;
} /***************external interrupt intializing function*********************************/ void ext_init() { EA=1; EX1=1; IT1=1; } void ext1(void) interrupt 2 {
solaniodflag=1; }
void start_poring(void) { val=0; MOT_REV=0; while(1) { MOT_FWD=1; delay(4); MOT_REV=0; delay(20); val++; if(val==150) break; } }
What a brilliant idea. Keep on compiling the same syntatically incorrect code over and over again, until the compiler just gives up complaining and finally accepts it.
1. Post the code using the proper tags. 2. Post the complete compiler reported error.
1. Post the code using the proper tags. 2. Post the complete compiler reported error. 3, foloow the advice given here http://www.keil.com/forum/20644/
the error is at line 3 #include"lcdbusy.h" ....is that a wrong command?what is command for lcd interface?
the error is at line 3 #include"lcdbusy.h" WHAT error?
....is that a wrong command?what is command for lcd interface? who, but you would know?
the error is at line 3 that was a (failed) attempt to take care of 2), what about 1) and 3)?
Perhaps #include "lcdbusy.h" Not #include"lcdbusy.h"
you should place the lcdbusy.h on target folder. Please use proper tags as mentioned below the summary.
