I2C Error function I2C_Send7bitAddress
Example code:
/* Includes ------------------------------------------------------------------*/
#include "stm32F10x.h"
#include "stm32f10x_i2c.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define ClockSpeed            400000
#define I2C_SLAVE_ADDRESS7      0x74
#define PCF8535_FLAG_TIMEOUT         ((uint32_t)0x1000)
#define PCF8535_LONG_TIMEOUT         ((uint32_t)(10 * sEE_FLAG_TIMEOUT))
/* Private macro -------------------------------------------------------------*/
/* Private consts ------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
u32 count = 0;
GPIO_InitTypeDef GPIO_InitStructure;
I2C_InitTypeDef I2C_InitStructure;
/* Private function prototypes -----------------------------------------------*/
int main(void)
  /* Enable GPIOx Clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO , ENABLE);
  /* Initialise GPIO port */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* Enables the specified I2C peripheral. */
  I2C_Cmd(I2C1, ENABLE);
  /* Initialise I2C */
  I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  I2C_InitStructure.I2C_OwnAddress1 = 0x78;
  I2C_InitStructure.I2C_Ack = I2C_Ack_Disable ;
  I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  I2C_InitStructure.I2C_ClockSpeed = ClockSpeed;
  I2C_Init(I2C1, &I2C_InitStructure);
  while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));
  I2C_GenerateSTART(I2C1, ENABLE);
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
  I2C_Send7bitAddress(I2C1, 0x78, I2C_Direction_Transmitter);
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED ));
  I2C_SendData(I2C1, I2C_SLAVE_ADDRESS7);
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED ));
  I2C_SendData(I2C1, 0x01);
//  I2C_SendData(I2C1, 0x20);
//  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED ));
//  I2C_SendData(I2C1, 0x09);
  I2C_GenerateSTOP(I2C1, ENABLE);
  /* main while */
  while(1)
The program gets into an endless loop on the line: while (! I2C_CheckEvent (I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
Debugged on the simulator. In the define: "STM32F10X_MD, USE_STDPERIPH_DRIVER"
stm32f10x_stdperiph_lib version V3.4.0
Interrupts are not used.
I looked through all the documentation, but was not able to run the I2C.
Sorry for bad English.
PS: The country Russia and the U.S. flag. I missed something?
  • Attention!
    Found an error in stm32f10x_i2c.c version V3.4.0 of 10/15/2010!
    Function void I2C_Init (I2C_TypeDef * I2Cx, I2C_InitTypeDef * I2C_InitStruct)
    incorrectly fills register I2C_OAR1 - and specifically the field of ADD
    Make no mistake: the 10-bit mode, the address is written to bits [0 .. 9], and in 7-bit - in bits [1 .. 7].
    and the library is done as follows:
    I2Cx-> OAR1 = (I2C_InitStruct-> I2C_AcknowledgedAddress | I2C_InitStruct-> I2C_OwnAddress1);
    The address is written with 0 bits, without any verification regime addressing.
    When forming the address coincidence circuit waits generated odresa and addresses OAR1. After that forms the flags. And as the address in OAR1 stuck with 0 bits rather than 1 (ie, shifted by 1 bit), then the flags properly generating addresses will never lift a. And everything hangs until timeout.
  • Hi Sergei Danilin,
    sorry but I did not understand the answer. Could you please write a response to this thread, what is wrong with the library and what I must do to make it run.
    I have an ic whose address is 0x90 and I am using 7bitadressing. I have same problem like your problem.
    thanks in advance.
  • He said 7-bit addresses should be stored in "in bits [1 .. 7]."
    Note that bit 0 then is unused - so the claim is probably that the library forgot to shift the address one step left - or expected that the user should have already given a shifted address.
