HI, can i know what is the maximum read speed for SD card interface in LPC2468 OEM board.
Yes - if you study the Datasheet for the LPC2468 !
You will also have to study the documentation for the OEM board - to see if its design imposes any limitations.
hi, Thanks for your reply. I'm using an Embedded Artists LPC2468 board for development. Part of my application requires a large amount of data to be read from SD card, processed and written to an external hi-speed USB interface.I used 2GB micro SD card and the transfer speed is 4.5MBps. can i get high-speed reads on the MCI than this? I gone through the data sheet but i didn't get necessary data from that.
Then you obviously need to speak to Embedded Artists if you want specific details about their product - don't you?
This is the Keil forum for discussing Keil products; you wouldn't go into a Ford dealer to ask questions about a Toyota - would you?!
