I declare 32 bit variables in the MyAsmVar section.
I know the base address of MyAsmVar. Also I know the address of var1 and var2.
AREA MyAsmVar, DATA,NOINIT, READWRITE, ALIGN=3
var1 DCD 0x00 var2 DCD 0x00
LDR R0,=0x20000000 ; base address of MyAsmVar LDR R1,[R0,#0] ; read var1 in to R1 (var1 address is 0) LDR R2,[R0,#4] ; read var2 in to R2 (var2 address is 4)
We must know the numeric value of variable address and this is not good.
How can I use the variables names instead of address?
I want the following lines but compiler give error messages;
LDR R0,=0x20000000 LDR R1,[R0,#var1] ; read var1 in to R1 LDR R2,[R0,#var2] ; read var1 in to R2
Also i try following lines but compiler dont compile.
LDR R1,[R0,#&var1] ; read var1 in to R1 LDR R2,[R0,#&var2] ; read var1 in to R2
if I use
var1 equ 0 var2 equ 4
problem solving, but i dont want to count address of variables.
You can do:
var1 DCD 0x00 var2 DCD 0x00 LDR R0,=var1 ; Address of var1 LDR R1,[R0] ; read var1 in to R1 LDR R0,=var2 ; base address of MyAsmVar LDR R2,[R0] ; Address of var2
Thanks for your answer.
Are there short method?
How I can write at the single line
like this LDR R1,[R0,#var1] ; Address of var1
Not that I'm aware of.
IF you want programmer convenience, then use a High-Level Language.
You could of course write a simple macro.
@Andrew
Dont wory I use also C.
@IB
var1 DCD 0x00 ; Address 0x20000000 var2 DCB 0x00 ; Address 0x20000004 var3 DCD 0x00 ; Address 0x20000006
var1_ EQU 0x00 var2_ EQU 0x04 var3_ EQU 0x06
LDR R0,=0x20000000 ; Ram Base Address LDR R1,[R0,#var1_] LDR R2,[R0,#var2_] LDR R3,[R0,#var3_]
you see need only 4 line.
This solves my problem but not good idea. Because we must find (count) the values of var1_,var2_,var3_.
Other way (you said)
LDR R0,=var1 LDR R1,[R0] LDR R0,=var2 LDR R2,[R0] LDR R0,=var3 LDR R3,[R0]
need 9 lines. Because LDR R0,=var1 pseudo code.
LDR R0,=var1 (LDR R0,[PC+adr1]) LDR R0,=var2 (LDR R0,[PC+adr2]) LDR R0,=var3 (LDR R0,[PC+adr3])
adr1 0x20000000 adr2 0x20000004 adr3 0x20000006
8086, 8051, PIC ... assembler compiler easyly solves this problem. Why i cant do by keil i dont know.
For example for x86
var1 dw 0 var2 db 0 var3 db 0
mov ax,var1 mov bh,var2 mov bl,var3
"Why i cant do by keil i dont know."
The differences you note are due to the processors having different architectures.
"8086, 8051, PIC ... assembler compiler easyly solves this problem."
What problem do you think you have? speed? code size? complexity?
It might be worth you reading about some of the design philosophy that lies behind the ARM core.
You ask to me "What problem do you think you have? speed? code size? complexity?"
Speed and Code Size importand for me. Complexity no problem.
The whole point of Assembler is that it has a direct 1:1 correspondence to machine instructions.
The Assembler doesn't "solve" anything - it simply gives you direct access to the processor's instruction set - nothing added, nothing taken away. It leaves you to do all the "solving" using those instructions.
The assembler cannot invent instructions that are not present in the hardware instruction set.
What makes you think that you can beat the compiler at this?
Okey i am writing again.
var1 and var2 are 32 bit variables. I can easly learn the values of this variables if i know the var1 and var2 address.
for example
var1 variable's address is 0x20000000. var2 variable's address is 0x20000004.
Base_Addr=0x20000000
var1 relative address is 0 var2 relative address is 4
LDR R0,=0x20000000 LDR R1,[R0,#0] LDR R2,[R0,#4]
or
i can define
val1 equ 0x00 val2 equ 0x04
and after
LDR R0,=0x20000000 LDR R1,[R0,#val1] LDR R2,[R0,#val2]
Ok?
These are not problem.
if i dont know the var1 and var2 address what can i do?
Base address is 0x20000000
varx dcb 0x00 vary dcb 0x00 ... ... ... var1 dcd 0x00 var2 dcd 0x00
Compiler give error message for #var1 and #var2
Ok i may be wrong write it. There for compiler give error messages.
what is the true form? (You say it)
I need simple directive name but i dont know it.
For example you say to me "use LDR R1,[R0,#AdrOf(val1)]"
Thats all....
"what is the true form? (You say it)"
There is no one true form. I have already given you a workable alternative.
If code size is important, then you might well be better off looking at the thumb instruction set.
If you REALLY want to do it your way then you could have a series of equates, something like:
. . . VarBase ;Base address for the following variables Var1 dcb 0 ;Variable #1 Var2 dcb 0 ;Variable #2 OFFSET_VAR1 set Var1-VarBase ;Offset from VarBase for Var1 OFFSET_VAR2 set Var2-VarBase ;Offset from VarBase for Var2 . . . LDR R0,=VarBase ;Set R0 to base address of variable block LDR R1,[R0,#OFFSET_VAR1] ; LDR R2,[R0,#OFFSET_VAR2]
WARNING: This code block is intended to illustrate a possible method. It is not complete and may have syntax errors.
Ok i am giving simple C example.
int a,b,c;
int main() { a=1; b=2; c=3; }
Select optimization level 0 and compile it.
You will see following asm codes in the debug menu.
5: a=1; 0x000001C8 2001 MOVS r0,#0x01 0x000001CA 4905 LDR r1,[pc,#20] ; @0x000001E0 0x000001CC 6008 STR r0,[r1,#0x00] 6: b=2; 0x000001CE 2002 MOVS r0,#0x02 0x000001D0 4904 LDR r1,[pc,#16] ; @0x000001E4 0x000001D2 6008 STR r0,[r1,#0x00] 7: c=3; 0x000001D4 2003 MOVS r0,#0x03 0x000001D6 4904 LDR r1,[pc,#16] ; @0x000001E8 0x000001D8 6008 STR r0,[r1,#0x00]
This code same as your suggested codes.
Now select optimization level 3 and recompile it.
5: a=1; 0x000001C8 4804 LDR r0,[pc,#16] ; @0x000001DC 0x000001CA 2101 MOVS r1,#0x01 6: b=2; 0x000001CC 6001 STR r1,[r0,#0x00] 0x000001CE 2102 MOVS r1,#0x02 7: c=3; 0x000001D0 6041 STR r1,[r0,#0x04] 0x000001D2 2103 MOVS r1,#0x03 8: } 0x000001D4 6081 STR r1,[r0,#0x08]
This codes same as my need codes.
You see C compiler solve this problem. But we can't do by assembler.
How I can do?
Of course you can - and you also got one example how to do it.
The difference between assembler and C is that with assembler, you have to do all the extra work that the compiler does on its own.
It's up to you to declare three individual variables, or to just allocate storage large enough for three variables and then play with the individual offsets. Or to try to do the IB Shy workaround, writing extra assembler lines to compute the offsets.
Other cpu's compilers has $ or offset type asm directives. But i didnt find in the keil.
I can't solve this problem If i don't find the address learning directives.
