i would like to be helped with clearing yhe errors in this program
#include<reg51.h>
#include<GSM_init.h>
unsigned char L,Lg[12],key,x[4],Po,count,z;
bit f2,f3,f4,f5;
sbit IOE1=P3^7; sbit IOE2=P3^6;
sbit m1=P1^0;sbit m2=P1^1;
sbit m3=P1^2;sbit m4=P1^3;sbit as=P3^2;sbit cs=P1^7;sbit ent=P3^3; sbit inc=P3^4;sbit dec=P3^5;
void main(void);
void serial(void) interrupt 4 using 1
{ if(RI)
{ a[i]=SBUF;
RI=0;
if(SBUF=='*')
{ f2=1;
EA=0;
} i++;
if(SBUF=='$')
{ i=0;
} void clear()
{ for(i=0;i<42;i++)
{ a[i]='\0';
GPS_track()
{ IOE1=1;
IOE2=0;
ES=1;
cmd(0x80);
11: sconf1();
EA=1;
delay(50);
EA=0;
if(a[0]=='G' && a[1]=='P' && a[2]=='G' && a[3]=='G' &&a[4]=='A' && a[27]=='N')
{ goto 12;
} Else
{ clear(); EA=1;goto 11;
} 12: cmd(0x01); cmd(0x80);
for(i=6;i<22;i++)
{ DT(a[i]);
} cmd(0xc0);
for(i=22;i<38;i++)
{ DT(a[i]);
} Po=0;
for(i=17;i<29;i++)
{ Lg[Po]=a[i];Po++;
} IOE1=0;
IOE2=1;
GSM_setup();
EA=0;
serial_tx("AT+CMGS=");
serial_tx1(0x22);
serial_tx("+255712279439");
serial_tx1(0x22);
serial_tx1(0x0d);
delay(10);
serial_tx("Logitude:");
for(i=0;i<4;i++)
{ serial_tx1(Lg[i]);
} serial_tx(" Latitude:");
for(i=5;i<11;i++)
} serial_tx1(0x1a);
cmd(0x01);
DTS("msg sent");
for(i=0;i<42;i++)
{ a[i]='\0';
} EA=1;
cmd(0x01);cmd(0x80);DTS("welcome");
} void start()
{ m1=1;m2=0;m3=1;m4=0;
} void stop()
{ m1=1;m2=1;m3=1;m4=1;
} void main()
{ IOE1=0;
IOE2=1;
GSM_setup();
L=0;f2=0;f3=0;f4=0;f5=0;key=0;
while(1)
{ EA=1;count=0;cmd(0x01);
key=0;Po=0;
goto j2;
j1: key=0;Po=0;
cmd(0x80);DTS("Password :");
j2: if(ent==0)
{ while(ent==0);
while(count<2 && f4==1)
{ cmd(0x80);
DTS("Password :");
cmd(0x8a+Po);
DT(key+0x30);
if(inc==0)
{ while(inc==0);
if(key<9 && key>=0)
{ key++;
} else
{ key=0;
else if(dec==0)
{ while(dec==0);
if(key<9 && key>0)
{ key--;
} else
{ key=0;
else if(ent==0)
{ while(ent==0);
key=0;
Po++;
} x[Po]=key+0x30;
if(Po>=4)
{ if(x[0]=='1' && x[1]=='2' && x[2]=='3'&& x[3]=='4')
{ cmd(0x01);cmd(0xc0);DTS("correct pass u can");
delay(100);cmd(0x01);
delay(10);f4=0;f3=0;
count=0;
} else
{ cmd(0x01);cmd(0xc0);DTS("incorrect pass pls try");
count++;a[4]="";key=0;
delay(10);cmd(0x01);
goto j1;
if(count>=2)
{ cmd(0x01);cmd(0x80);DTS("Due to wrong pass");
cmd(0xc0);DTS("Vehicle P blocked");
while(1) ;
} if(cs==0 && as==1 && f3==0)
{ start();
cmd(0x01);cmd(0x80);DTS("vehicle is going");
} else
{ stop();
if(as==0)
{ f3=1;
cmd(0x01);cmd(0x80);DTS("vehicle is crashed");
EA=0;
serial_tx1(0x22);
serial_tx1(0x22);
serial_tx1(0x0d);
delay(10);
serial_tx(" ur vehicle is crashed");
serial_tx1(0x1a);
clear();
i=0;
delay(100);
EA=1;
f1=wait();
if(f1!=1)
{ goto intim;
} f1=0;
clear();L=0;i=0;
GPS_track();
while(f2==1)
{ i=0;
cmd(0x01);cmd(0xC0);
while(a[i]!='#')
{ i++;
} z=i;
for(i=z+1;a[i]!='*';i++)
{ DT(a[i]);
} delay(300);
if(a[z+1]=='B' && a[z+2]=='L' && a[z+3]=='O' &&a[z+4]=='C' && a[z+5]=='K' && a[z+6]=='*')
{ cmd(0x01);cmd(0x80);DTS("vehicle is blocked");
delay(300);
stop();
f3=1;f4=1;
} else if(a[z+1]=='T' && a[z+2]=='R' && a[z+3]=='A'&& a[z+4]=='C' && a[z+5]=='K' && a[z+6]=='*')
{ cmd(0x01);cmd(0x80);DTS("vehicle isTracking");
delay(200);cmd(0x01);clear();
GPS_track();
f1=0;
} i=0;z=0;
for(i=0;i<43;i++)
{ a[i]='\0';
} f2=0;
EA=1;
} cmd(0x01);cmd(0xc0);DTS("Waiting for mess");
  • Well, you certainly know how to break a forum!
    I think you need to start a new thread, and make your post properly, this time:
    1. Take care to read and follow the posting instructions - as shown in this picture: www.danlhenry.com/.../keil_code.png
    2. Take care to clearly explain what errors you're getting, what efforts you've made to resolve them, and what were the outcomes.
    3. Use the 'Preview' to confirm that it looks good before you post!
    4. Update this thread with a link to your new thread.
  • This bug have existed for a number of years. Keil really should fix it. It really is not a big job to figure out what condition that trigs it.
    But at the same time, they should add some form of code scanner logic - preferably using javascript - that looks for percentage of C keywords and pop up a message "are you _sure_ you haven't posted source code in this post?" in a enough nagging way that people either do add the correct tags or leaves the forum.
