How to call a function after a specific clock period
hi
I am using 89c51. for using serial port I am using these commands
SCON  = 0x50;                  /* SCON: mode 1, 8-bit UART, enable rcvr    */
TMOD  = 0x20;                  /* TMOD: timer 1, mode 2, 8-bit reload      */
TH1   = 0xfd;                  /* TH1:  reload value for 9600 baud         */
TR1   = 1;                     /* TR1:  timer 1 run                        */
these are working correctly
but in main function i am calling 2 functions
for example
void main()
    while(1)
        if(RI)
            GetData();
        if(??????????)
            DisplayData();
At the location "??????????" I want to call the DisplayData() after a specific clock period, for example after every 1000 clocks. is it possible to set the timer0 of 89c51 for this purpose.
  • Set up a timer to generate an interrupt at the required rate;
    In the timer's Interrupt Service Routine, set a flag;
    In the main loop, test this flag
    void main()
        while(1)
            if(RI)
                GetData();
            if( time_to_display_data )
                // The flag is set - it's time to display the data
                DisplayData();
                // Clear the flag ready for next time...
                time_to_display_data = 0;
    Simples!
  • Note that the above is not specific to the 8051 - the approach would work for any processor with a timer that can generate an interrupt.
