I'm actually trying to install sector/general protection as described in chapter 3.9 in the XC167-32 Manual. For testing, I use the function ActivateGeneralReadProtection(). When calling InstallSecurityFeatures(..) and monitoring PROCON in the Debugger, the Controll Bits are correctly installed. (see //**) But when trying to verify the Password executing DisableGeneralReadWriteProtection() the Password ist denied and in FSR the Bit PROER ist set (see //++). As the Password is the same, I don't know what could be wrong. Has anyone got an idea?
Best regards, Viviane
void ResetToReadMode() { volatile unsigned int far *Flash_Command = (unsigned int far *)0x0C000AA; *Flash_Command = 0x00F0; } void ClearStatus() { volatile unsigned int far *Flash_Command = (unsigned int far *)0x0C000AA; ResetToReadMode(); *Flash_Command = 0x00F5; } int Read_FSR() { volatile unsigned int far *Flash_Register = (unsigned int far *)0xFFF000; return *Flash_Register; } void Read_FSR_Busy() { unsigned int Register = Read_FSR(); while(Register & 0x0001) { Register = Read_FSR(); } } int Read_PROCON() { volatile unsigned int far *Flash_Register = (unsigned int far *)0xFFF004; return *Flash_Register; } int CheckError() { unsigned int Register = Read_FSR(); if(Register & 0x00C0) { return 0; } else { return 1; } } int EraseSecurityWordline(unsigned long ulSecurityWordline) { volatile unsigned int far *Flash_Command_1 = (unsigned int far *)0x0C000AA; volatile unsigned int far *Flash_Command_2 = (unsigned int far *)0x0C00054; unsigned int far *Flash_Command_3 = (unsigned int far *) ulSecurityWordline; ClearStatus(); *Flash_Command_1 = 0x0080; *Flash_Command_2 = 0x00A5; *Flash_Command_3 = 0x0053; Read_FSR_Busy(); return (CheckError()); } int EnterSecurityPageMode(unsigned long ulSecurityPage) { volatile unsigned int far *Flash_Command_1 = (unsigned int far *)0x0C000AA; unsigned int far *Flash_Command_2 = (unsigned int far *) ulSecurityPage; ClearStatus(); *Flash_Command_1 = 0x0055; *Flash_Command_2 = 0x00AA; Read_FSR_Busy(); return (Read_FSR() & 0x08); //PAGE-Bit set? } int DisableGeneralReadWriteProtection(unsigned int *puiPassword) { volatile unsigned int far *Flash_Command_1 = (unsigned int far *)0x0C0003C; volatile unsigned int far *Flash_Command_2 = (unsigned int far *)0x0C00054; volatile unsigned int far *Flash_Command_3 = (unsigned int far *)0x0C000AA; volatile unsigned int far *Flash_Command_4 = (unsigned int far *)0x0C0005A; if (Read_FSR() & 0x400) //FSR Bit 10 = PRODI set? return 1; ClearStatus(); *Flash_Command_1 = 0x0000; *Flash_Command_2 = puiPassword[0]; *Flash_Command_3 = puiPassword[1]; *Flash_Command_2 = puiPassword[2]; *Flash_Command_3 = puiPassword[3]; *Flash_Command_4 = 0x0055; //++ Read_FSR_Busy(); if (Read_FSR() & 0x80) //FSR Bit 7 = PROER set? { ResetToReadMode(); return 0; //wrong PW } if (Read_FSR() & 0x400) return 1; return 0; } int InstallSecurityFeatures(unsigned int *puiPassword, unsigned int uiPROCON) { char *pcBufferWord; volatile unsigned int far *PageBuffer = (unsigned int far *) 0xC000F2; volatile unsigned int far *Flash = (unsigned int far *)0x0C000AA; volatile unsigned int far *Write_Page = (unsigned int far *)0x0C0005A; unsigned long ulSecurityWordline0 = 0xC00000; unsigned long ulSecurityWordline1 = 0xC00100; unsigned long ulSecurityPage1 = 0xC00080; unsigned long ulSecurityPage2 = 0xC00100; if(!EraseSecurityWordline(ulSecurityWordline0)) return 0; if(!EraseSecurityWordline(ulSecurityWordline1)) return 0; if(!EnterSecurityPageMode(ulSecurityPage2)) return 0; pcBufferWord = (char*) &uiPROCON; *PageBuffer = *pcBufferWord; *PageBuffer = *(pcBufferWord+1); *PageBuffer = puiPassword[0]; *PageBuffer = puiPassword[1]; *PageBuffer = puiPassword[2]; *PageBuffer = puiPassword[3]; //** *Flash = 0x00A0; *Write_Page = 0x00AA; Read_FSR_Busy(); if(!DisableGeneralReadWriteProtection(puiPassword)) return 0; //Install Configuration Code // EnterSecurityPageMode(ulSecurityPage1); // pcBufferWord = (char*) &g_couiConfirmationCode; // *PageBuffer = *pcBufferWord; // *PageBuffer = *(pcBufferWord+1); // *Flash = 0x00A0; // *Write_Page = 0x00AA; // // Read_FSR_Busy(); //if(Read_FSR() & 0x400) return 1; } const unsigned int g_couiPW[4] ={0xFFAA, 0xFFBB, 0xFFCC, 0xFFDD}; void ActivateGeneralReadProtection() { unsigned int uiProcon = Read_PROCON() | 0x8000; InstallSecurityFeatures(g_couiPW, uiProcon); }
