bitmap image on glcd
i want to display the bitmap image on GLCD, Any software for generating array of hex for the bitmap.?
waiting for ur response,,,
shyam.
What is "the bitmap"? The GLCD can most probably not display a GIF, PNG, TIFF etc but needs a raw bitmap image. Where do you get such a bitmap from?
There are a number of programs available that can convert binary data into heither Intel Hex data that can be downloaded directly into a target, or maybe a C array with bytes expressed in hexadecimal, for inclusion in the source code like:
unsigned char my_bitmap[] = { 0x17,0x14,0x47,... ];
Since google works so well for finding a program converting binary data, your first job is to figure out where to get a raw bitmap. Unless you plan to add decode functionality so you can take a full image file. The advantage with decode logic is that you can use compressed images. Slower to display, but takes way less space.
BIN2C.COM can convert a .bmp file to an array which can be included in a C program.
www.programmersheaven.com/.../download.aspx
-Walt
