Friends,
I like to make some changes on a code writed on UVISION C, Downloadable on www.keil.com/.../c51.htm
I've a full evaluation version of UVISION IDE.
When try to compile the original called ToasterControl_Jenifer_v0.05k8x_testprogram.C, with previous add of complonent boostc.h and boostc.h, only obtain a error. I suppose all three components are correct and the error is mine.
Then I request a big help, please...
Should we hack Keil to get the IP number to your computer and then continue by hacking your machine - just to be able to see your source code and the error messages you get?
Or exactly how did you think anyone would be able to help you?
Two questions:
1) how can anyone be so "challenged" in performing such a simple task (asking for help)?
2) why are there so many such "challenged" people / posts on this forum?
Are you toasting Jennifer?!
We all know the chicks wants to spend a significant time in the sun getting the optimum brown surface. A toaster is much, much more efficient.
