Is this a C51 bug?
struct tag
    char a:7;
    char b:1;
unsigned char foo(void)
    struct tag test;
    test.b = 1;
    return test.b;
void main(void)
    char dat;
    if(foo() == 1)// ***foo return 0x80 not 0x01
        dat = 2;
    while(1);
17: void main(void) 18: { 19: char dat; 20: 21: if(foo() == 1)
C:0x000F 12001A LCALL foo(C:001A)
C:0x0012 BF0103 CJNE R7,#0x01,C:0018 22: { 23: dat = 2;
C:0x0015 750802 MOV 0x08,#0x02 24: }
C:0x0018 80FE SJMP C:0018 8: unsigned char foo(void) 9: { 10: struct tag test; 11: 12: test.b = 1; 13:
C:0x001A 430980 ORL 0x09,#P0(0x80) 14: return test.b;
C:0x001D E509 MOV A,0x09
C:0x001F 5480 ANL A,#P0(0x80)
C:0x0021 FF MOV R7,A 15: }
  • What is the sign-ness of char for your build?
    Assuming a char is signed then:
    You have an element with a width of 1 bit as a signed char.
    Does a 1 bit twos complement value make any sense?
    When you return the value it is being converted to an unsigned char.
    What conversion will occur?
    Likely that you intended your 1 bit variable to be unsigned.
    Try it.
  • struct tag
        unsigned char a:7;
        unsigned char b:1;
        struct tag test;
        test.b = 1;
        return test.b;
    void main(void)
        unsigned char dat;
            dat = 2;
        while(1);
    17: void main(void) 18: { 19: unsigned char dat; 20: 21: if(foo() == 1)// ***foo return 0x80 not 0x01
    THE RESULT IS THE SAME!
  • Keil support should be interested in this. Contact them.
  • As written, the code worked for me: dat is assigned a value of 2 and its branch is executed.
    however, if you change
    char dat;
    by giving dat a value, like
    char dat=1;
    the branch isn't executed.
    I didn't take a look at the disassembly but I tend to think that something isn't right here.
  • ... I tend to think that something isn't right here.
    I thought the same as you. When I first tried it with the signed char, things were obviously wrong and I thought I understood. When I converted to unsigned char, it looked right. I then tried it later and it didn't work. Must have done something different, but don't know what. This was all determined by looking at the disassembly.
