The jmp_buf defined in setjmp.h needs a large buffer, typedef __int64 jmp_buf[48]; //384 bytes
As we checked in function setjmp/longjmp used by Cortex M0/M3, it is used to save only few run-time data such as R0, R1, ...
On some platform which has very limited memory resource, the 384 bytes seems too expensive. What's the minimal size of jmp_buf?
Thanks!
Since you are considering modifying setjmp/longjmp shipped with the build tools, you might as well implement your own setjmp/longjmp. This way you'll be able to optimize them to the fullest. Yes, 384 bytes does seem excessive. I don't know what the minimum required size of jmp_buf is, but I think it's safe to assume that it only needs to be big enough to hold the data that setjmp saves.
I have to agree with you! Haha ...
