hi,
i am new to ARM7, i tried a code to receive characters through serial port and process the character in the serial port ISR. the code is getting interrupted, but the control is not switched to the corresponding ISR.please help me through this.
here is my code
#include <stdio.h> #include <lpc21xx.h>
void U1ISR(void)__irq; //Declare UART1 IRQ ISR
int data,clear,dummy;
void DefISR (void) __irq { ; }
int main (void) {
PINSEL0 = 0x00050000; /* Enable RxD1 and TxD1 */ IO1DIR = 0x00FF0000; /* P1.16..23 defined as Outputs */ IO1CLR= 0x00FF0000; /* turn off LEDs */
U1IER = 0; /* Disable UART1 Interrupts */ U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */ U1DLL = 97; /* 9600 Baud Rate @ 12MHz VPB Clock */ U1LCR = 0x03; /* DLAB = 0 */ U1FCR = 0x07; /*Enables and Resets FIFO, 1 byte */ dummy = U1IIR; /* Read IrqID - Required to Get Interrupts Started */ U1IER = 0x01; /*Enable the RDA interrupt*/
VICVectAddr0 = (unsigned long)U1ISR; //Set UART1 ISR Vector Address VICVectCntl0 = 0x20 | 7; //Enable Slot, Set Channel 7 VICIntEnable = 0x80; //Enable Int UART1 VICDefVectAddr = (unsigned long) DefISR; // un-assigned VIC interrupts
while (1) {
} //END OF WHILE LOOP } // END OF MAIN LOOP
void U1ISR(void)__irq //UART1 ISR { clear=U1LSR; //UART Line Status Register data = U1RBR; // UART Receiver Buffer Register data<<=16; IO1CLR=0x00FF0000; IO1SET=data; /*Displaying the DATA on GPIO1*/ VICVectAddr = 0; /* Acknowledge Interrupt*/ return; }
thank you.
I don't know the LPC21xx very well - maybe you mishandle "DefISR" in some way? Don't you need to acknowledge it (still, this might indicate that there is something else going wrong as your program should never end up in that ISR).
Before just trying random code, you should be sure that you have at least a basic understanding of how it's supposed to work, and what it's intended to do.
Have you studied the Datasheet and/or User Manual and other supporting documentation for this particular chip? Do you understand how the interrupt mechanism works, and what your service routine needs to do?
One thing you certainly didn't study is the instructions on this forum for how to post source code:
www.danlhenry.com/.../keil_code.png
If you missed something as clearly stated as that, it is possible that you have also missed other important details in the chip's documentation...
"code is getting interrupted, but the control is not switched to the corresponding ISR"
So what is happening, then?
sorry for not following the posting rules. i am desperate about finishing this code. i also have gone through the manuals and data sheet for LPC2129 and develop the code only from the examples available on KEIL example codes.
here "code is getting interrupted, but the control is not switched to the corresponding ISR" means 1.the U1RBR is loaded with the value sent over serial port. 2.RDR bit is set in U1LSR 3.Bit 7 is set on the VICIRQStaus register 4.VICVectAddr is changed from 0x00000128 to 0x0000013C.(VICVectAddr0=0x0000013C)(in the VIC Box)
but the code written in the UART1 ISR is not invoked. in the ISR i tried to display the hex equivalent of the received character in the GPIO1 (bit16-bit23).
once the first character is received, the code becomes still.it cannot accept further characters.
since VICVectaddr is changed on receiving a character, i thought the DefVICVectAddr may not be significant.
Shouldn't you enable the interrupts _after_ you have installed the interrupt vector? What if you get one spurious interrupt before the vectors have been configured? Who will then acknowledge the interrupt?
How do you know that?
i placed a break point in the ISR routine and also changed the Interrupt enabling line after the interrupt configuration, but still the problem exists.
i also check the Program Counter data in the Watch window,it never goes to ISR address,that's why i felt ISR is not invoked.
i checked the same code with Polling method it is working fine.
the code is
#include <stdio.h> /* prototype declarations for I/O functions */ #include <lpc21xx.h> /* LPC21xx definitions */ void U1ISR(void)__irq; //Declare UART1 IRQ ISR int data,clear,dummy; char data1; void DefISR (void) __irq { VICVectAddr = 0; /* Acknowledge Interrupt*/ return; } int main (void) { VICVectAddr0 = (unsigned long)U1ISR; //Set UART1 ISR Vector Address VICVectCntl0 = 0x20 | 7; //Enable Slot, Set Channel 7 VICIntEnable = 0x80; //Enable Int UART1 VICDefVectAddr = (unsigned long) DefISR; // un-assigned VIC interrupts PINSEL0 = 0x00050000; /* Enable RxD1 and TxD1 */ IO1DIR = 0x00FF0000; /* P1.16..23 defined as Outputs */ IO1CLR= 0x00FF0000; /* turn off LEDs */ U1IER = 0; /* Disable UART1 Interrupts */ U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */ U1DLL = 97; /* 9600 Baud Rate @ 12MHz VPB Clock */ U1LCR = 0x03; /* DLAB = 0 */ U1FCR = 0x07; /*Enables and Resets FIFO, 1 byte */ dummy = U1IIR; /* Read IrqID - Required to Get Interrupts Started */ U1IER = 0x01; /*Enable the RDA interrupt*/ while (1) { if(U1LSR & 0x01) { clear=U1LSR; data1 = U1RBR; // UART Receiver Buffer Register while (!(U1LSR & 0x20)); U1THR = data1; } } //END OF WHILE LOOP } // END OF MAIN LOOP void U1ISR(void)__irq //UART1 ISR { clear=U1LSR; //UART Line Status Register data = U1RBR; //UART Receiver Buffer Register data<<=16; IO1CLR=0x00FF0000; IO1SET=data; /*Displaying the DATA on GPIO1*/ VICVectAddr = 0; /* Acknowledge Interrupt */ return; }
here the main's loop code echo the character on UART, this works fine. but the ISR is not working.
