Can anyone assist with the availability of a USB component that allows communication with the USB device. The same as a RS232 component can connect and communicate with a RS232 device. But for USB devices.
Look in the "boards" folder where you installed the MDK.
A software "component", or a hardware "component" ?
so what i need is the .net object.
that has absolutely nothing whatsoever to do with Keil!!
At that level, your application neither knows nor cares about USB - it just sees a COM port, or a storage device, or...
