Lookup table in assembly
I need to write a lookup table in assembly so I'm looking for some example or docu hint.
I remember spitting through the C:\Keil directories seeing something like that but I can't find it back. Or maybe I saw it elsewhere...
Thanks,
Henk
  • Hi,
    I mean: a JUMP-table, not LOOKUP table..
    Henk
  • Hi,
    I'm sorry but I don't know what 'SWI' means...
    but in the meantime I found it back, it was in the helpfiles!
    Thanks for listening anyway.
    Henk
  • Here is your lookup table:
    ;/* SWI.S: SWI Handler                                                        */
    ;/* This file is part of the uVision/ARM development tools.                   */
    ;/* Copyright (c) 2005-2006 Keil Software. All rights reserved.               */
    ;/* This software may only be used under the terms of a valid, current,       */
    ;/* end user licence from KEIL for a compatible version of KEIL software      */
    ;/* development tools. Nothing else gives you the right to use this software. */
    T_Bit           EQU     0x20
                    PRESERVE8                      ; 8-Byte aligned Stack
                    AREA    SWI_Area, CODE, READONLY
                    ARM
                    EXPORT  SWI_Handler
    SWI_Handler
                    STMFD   SP!, {R12, LR}         ; Store R12, LR
                    MRS     R12, SPSR              ; Get SPSR
                    STMFD   SP!, {R8, R12}         ; Store R8, SPSR
                    TST     R12, #T_Bit            ; Check Thumb Bit
                    LDRNEH  R12, [LR,#-2]          ; Thumb: Load Halfword
                    BICNE   R12, R12, #0xFF00      ;        Extract SWI Number
                    LDREQ   R12, [LR,#-4]          ; ARM:   Load Word
                    BICEQ   R12, R12, #0xFF000000  ;        Extract SWI Number
                    LDR     R8, SWI_Count
                    CMP     R12, R8
                    BHS     SWI_Dead               ; Overflow
                    ADR     R8, SWI_Table
                    LDR     R12, [R8,R12,LSL #2]   ; Load SWI Function Address
                    MOV     LR, PC                 ; Return Address
                    BX      R12                    ; Call SWI Function
                    LDMFD   SP!, {R8, R12}         ; Load R8, SPSR
                    MSR     SPSR_cxsf, R12         ; Set SPSR
                    LDMFD   SP!, {R12, PC}^        ; Restore R12 and Return
    SWI_Dead        B       SWI_Dead               ; None Existing SWI
    SWI_Cnt         EQU    (SWI_End-SWI_Table)/4
    SWI_Count       DCD     SWI_Cnt
                    IMPORT  __SWI_8
    SWI_Table
                    DCD     SWI_Dead               ; SWI 0 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 1 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 2 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 3 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 4 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 5 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 6 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 7 Function Entry used by RTX
                    DCD     __SWI_8                ; SWI 8 Function Entry
    SWI_End
                    END
