LPC2148 interfacing with VS1033D
I am trying to interface vs1033d mp3/aac decoder with LPC2148.I wrote code for testing sine test on vs1033d...but it is not working.
So, to activate the sine test these are the steps,
- Reset the VS chip
- Set the ALLOW_TESTS bit in the SCI_MODE register (register 0)
- Make sure the XCS is high (never have both XCS and XDCS low at the same time)
- Pull XDCS low
- Send the 8 byte sequence to the SPI bus
- Wait for the sending of bytes to be complete
- Pull XDCS back high
You should now hear the beep.
i m writing my code here..please check the code and help me what is wrong in it..
// C main line
#include <lpc214x.h>
#include "integer.h"
#define xReset 0x00002000; //P0.13 es Reset
#define xDCS 0x00004000; //P0.14 as Bsync
#define xCS 0x00000080; //P 0.7 as CS_SPI
#define DREQ 0x00001000; //P0.12 es DREQ
void VS1033_SCI_write(unsigned char, unsigned short int);
unsigned short int VS1002_SCI_read(unsigned char);
void VsSineTest(void);
void Delay(unsigned int milliseconds);
BYTE SPI_Send(BYTE data);
void SPI_Init ();
void SPI_Init ()
PINSEL0 |= 0x1500; //Configure the SPI I/O. VPBDIV = 0x02; S0SPCCR = 0x12; //SPI Preescaler. S0SPCR = 0x20; //SPI master configuration.
/* send and receive a byte on the SPI bus */
{ S0SPDR = data; while (!(S0SPSR & 0x80)){} return S0SPDR;
/* main */
int main(void) { SPI_Init(); IODIR0 = xReset ; IODIR0 = xDCS; IODIR0 = xCS ; IODIR0 &= ~DREQ; VsSineTest();
{ int i;
IOCLR0 = xReset;
SPI_Send(0xff);
IOSET0 = xReset;
Delay(100);
while((0X00001000)==0) ;
/* As an example, let's write value 0x0820 to register 00 byte by byte */
IOCLR0 = xCS; SPI_Send(0x02); SPI_Send(0x00); SPI_Send(0x08); SPI_Send(0x20);
IOSET0 = xCS; /* Now SPI writes don't go to SCI port */
/* Send a Sine Test Header to Data port */ IOCLR0 = xDCS; /* Now SPI writes go to SDI port*/
SPI_Send(0x53); SPI_Send(0xef); SPI_Send(0x6e); SPI_Send(0x44); SPI_Send(0x00); SPI_Send(0x00); SPI_Send(0x00); SPI_Send(0x00); Delay(200); IOSET0 = xDCS;
Delay (200);
/* Stop the sine test sound */ IOCLR0 = xDCS; SPI_Send(0x45); SPI_Send(0x78); SPI_Send(0x69); SPI_Send(0x74); SPI_Send(0x00); SPI_Send(0x00); SPI_Send(0x00); SPI_Send(0x00); Delay(200); IOSET0 = xDCS;
Delay(500);
{ volatile unsigned int i; while(milliseconds--) { for(i=0;i<60000;i++); __asm__ ("nop"); }
