LPC2388 ethernet driver problem
Dear all,
We have designed a board using LPC2388 and DP83848 PHY referencing the MCB2300 schematics. I am trying to test the ethernet driver for it and cannot receive any new frames. It doesn't call EMAC Ethernet Controller Interrupt function - interrupt_ethernet(void) at all.
I have compiled the ftp_demo example and debugged it. It can intialize the ethernet interface but do not receive any new frames. Please see the debug output at uart0 below:
MEM: Initialize Memory Pool 8192 bytes
ETH: Initialize Ethernet interface
ARP: Initialize 10 Cache entries
UDP: Initialize 2 Sockets
TCP: Initialize 6 Sockets
FTP: Initialize 3 Sessions, Port 21
TCP: Socket 1 allocated
TCP: Socket 1 Listen
TCP: Socket 2 allocated
TCP: Socket 3 allocated
TCP: Socket 3 Listen
TCP: Socket 4 allocated
TCP: Socket 5 allocated
TCP: Socket 5 Listen
TCP: Socket 6 allocated
NBNS:Initialize NetBIOS Name Service
UDP: Socket 1 allocated
UDP: Socket 1, port 137 Opened
Any tip to my problem would be helpful.
thank you
Tirumal
  • Wouldn't it be more appropriate to use a much lower-level example for such low-level debugging...?
  • Hi,
    I have only used the examples provided in MCB2300. I didn't find any lower level examples in Boards/Keil/MCB2300
    I have tested the same ftp_demo example on MCB2300 Eval Board and it can process frames and works fine.
    Regards,
    Tirumal
  • You said you have "designed" a board.
    An essential part of that is to have a test & debug strategy in mind...
    I would suggest that you start by making simple test/debug routines on the Keil board - things like reading & writing registers, toggling IOs, sending & receiving simple IP packets, loop-back,...
    Get these working on the Keil board, then run them on your own board.
  • Thank your for your suggestions. What wonders me is that inspite of having the same design as MCB2300, ethernet doesn't work.
    Does the schematic provided at keil website are current one or old version?
    Reading and Writing registers doesn't help me but I have to send simple IP packets, which I think i am doing with http_server/ftp example.
    I cannot debug much bcos of tcp/ip libs are provided from keil...hmmm
    I have to look why it is not entering the interrupt function: interrupt_ethernet and is cause of this problem.
    VICVectAddr21 = (U32)interrupt_ethernet;
    regards,
    Tirumal
