ADuC Interrupt problem - can't enable interrupts on ADuC7024
I am having an evaluation board from the ADI which contain ADXL345 and also MCU ADUC7024. I tried to build the files from the example code that they have provided.
As shown below is the example code,
#include <ADuC7024.H> /* ADuC7024 definitions */
void wait (void) { /* wait function */ unsigned long i; /* Delay var */
for (i = 0; i < 100000; ) { /* Delay for 10000 Counts */ i++; }
} void My_IRQ_Function(void);
int main (void) { T1LD = 0x20000; // Counter Value T1CON = 0xC4; // Enabled,Periodic,Binary and CLK/16 IRQ = My_IRQ_Function; // Specify Interrupt Service Rountine IRQEN = GP_TIMER_BIT; // Enable Timer1 IRQ
GP4DAT = 0x04000000; // P4.2 configured as an output. LED is turned on
while (1) { }
/* Interrupt Service Rountine */
void My_IRQ_Function()
{ if ((IRQSTA & GP_TIMER_BIT) != 0) // Timer1 IRQ? { GP4DAT ^= 0x00040000; // Complement P4.2 T1CLRI = 0; // Clear Timer IRQ } return ;
As shown above, the message error is:
.\Flash\Blinky.axf: Error: L6218E: Undefined symbol IRQ (referred from blinky.o).
Well, is there any command i need to enter into the startup code or anywhere else.
The interrupt handler also can't be called using the __irq method which i have tried few times. Therefore, i have found this interrupt method from the example they provided in the website and hoping someone would help me to solve this issue. Thanks a lot.
Please leave a message if you know about this.
Regards.
  • Sorry for the direct copy from the coding which makes a little bit of confusion. Here is the corrected version for better viewing purposes.
    void wait (void)
    int main (void)
    while (1) {
    Please do comment if anything you can help. Thanks.
     Author        : ADI - Apps            www.analog.com/MicroConverter
     Date          : Sept. 2005
     File          : TimerTrig1.c
     Hardware      : Applicable to ADuC702x rev H or I silicon
                     Currently targetting ADuC7026.
     Description   : Demonstrates Timer 1 causing an interrupt and complements
                                     P4.2 every 50ms.
    #include<ADuC7026.h>
    int main (void)  {
            while (1)
            return ;
    The coding once again for proper viewing..
    The error message:
  • IRQ = My_IRQ_Function;
    Is this really how you are expected to map an interrupt service routing with a device for your specific processor? What does the user manual/datasheet/application nodes/sample code show?
    Doesn't it have any support for vectorized interrupts, in which case an ISR can lookup which of multiple interrupt sources that needs processing?
    Unless this is a Cortex chip, you normally also needs a __irq keyword for an ISR (unless the assembler startup code takes care of all entry/exit handling and is happy with a standard C function)
  • That seems to be a perfectly reasonable & correct statement about your code:
    int main (void)  {
            while (1)
    You clearly make a reference to the symbol IRQ - on the left-hand side of an assignment, highlighted above - and you have shown no definition of that symbol!
