I got PCB where a Bluetooth modul is SMD mounted at USART2 and a STM32F103ZE T6 (High Density). I'm using Keil + cmsis + stlib3.5.0
I'm trying to get the BT Modul working. For that I need to see what the USART2 is echoing from my BT-Module and I have to write some AT-Commands to the USART2 from a debug window in keil (is that possible?)
Can anyone help me?
I started to do my retarget.c, it looks like this but i dont know if its correct or not:
#include <stdio.h> #include <rt_misc.h> #pragma import(__use_no_semihosting_swi) extern int SendChar (int ch); /* In Serial.c */ struct __FILE { int handle; /* Add whatever you need here */ }; FILE __stdout; int fputc (int ch, FILE *f) { return (SendChar(ch)); } int ferror (FILE *f) { /* Your implementation of ferror */ return EOF; } void _ttywrch (int ch) { SendChar(ch); } void _sys_exit (int return_code) { for (;;); }
and my stmdbg.ini for the ULINK2:
FUNC void DebugSetup (void) { _WDWORD(0xE0042004, 0x00000027); // DBGMCU_CR _WDWORD(0x40044064, 0x00000003); // Enable SWO on P0.9 } DebugSetup(); // Debugger Setup
and my serial.c
/******************************************************************************/ /* SERIAL.C: Low Level Serial Routines */ /******************************************************************************/ /* This file is part of the uVision/ARM development tools. */ /* Copyright (c) 2005-2007 Keil Software. All rights reserved. */ /* This software may only be used under the terms of a valid, current, */ /* end user licence from KEIL for a compatible version of KEIL software */ /* development tools. Nothing else gives you the right to use this software. */ /******************************************************************************/ #define ITM_Port8(n) (*((volatile unsigned char *)(0xE0000000+4*n))) #define ITM_Port16(n) (*((volatile unsigned short*)(0xE0000000+4*n))) #define ITM_Port32(n) (*((volatile unsigned long *)(0xE0000000+4*n))) #define DEMCR (*((volatile unsigned long *)(0xE000EDFC))) #define TRCENA 0x01000000 #include <stm32f10x_lib.h> /* STM32F10x Library Definitions */ /* Implementation of putchar (also used by printf function to output data) */ int SendChar (int ch) /* Write character to Serial Port */ { #ifdef DBG_ITM if (DEMCR & TRCENA) { while (ITM_Port32(0) == 0); ITM_Port8(0) = ch; } #else USART_SendData(USART2, (unsigned char) ch); while (!(USART2->SR & USART_FLAG_TXE)); #endif return (ch); } int GetKey (void) /* Read character from Serial Port */ { while (!(USART2->SR & USART_FLAG_RXNE)); return (USART_ReceiveData(USART2)); }
/////////////////////////////////////////////////////////////////////////////////// If anyone has something finshed please share or give some good adivce :)
with regards Sven
and my USART2 setup in setup.c
void SetupBT (void) { /* USART2 Clock */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); /*Init USART2 USART2: CTS PA0, RTS PA1, TX PA2, RX PA3 */ /* Configure USART2 RTS and USART2 Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure USART2 CTS and USART2 Rx as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); USART_InitStructure.USART_BaudRate = 38400; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_RTS_CTS; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART2, &USART_InitStructure); USART_Cmd(USART2, ENABLE); /* Init BT */ /*here i need the printf and "cout" function, to check the echo replying from the BT over USART2 */ IMU_Led1_On(); Delay(100); send_string("STWMOD=0\r\n"); send_string("STBD=38400\r\n"); Delay(200); send_string("STNA=IMU\r\n"); send_string("STAUTO=0\r\n"); send_string("STOAUT=1\r\n"); send_string("STPIN=0000\r\n"); Delay(200); send_string("INQ=0\r\n"); Delay(200); }
please have a look at the CMSIS (core_cm3.h) function ITM_SendChar(). You should use this. In the Keil STM32 Examples you'll also find a simpler example for setting up the UARTs :-)
. BR, /th.
