REGARDING FX360
HELLO, I P SOMASEKHAR BABU.I AM DESIGN A PCM ENCODER IN THE SCHEMATIC DIAGRAM I AM HAVING A 3 NO.OF MCU UNITS FX360/1/2/3/6/7(SILICON LAB)DVICES. I HAVE A PROBLEM FOR WRITING A SOURCE CODE FOR EXTERNAL FLASH . I KNOW THE PROCEDURE FOR WRITING ,READING AND ERASING IN INTERNAL CODE IN PROCESSER I WANT EXTERNAL SOURCE CODE FOR EXTERNAL FLASH,PLEASE PROVIDING ME REGARDING THIS INFORMATON
  • 1) Before you take on advanced tasks, you should make sure your equipment is in good working order. We have detected a keyboard malfunction - for some reason the keyboard caps-lock key seems to be broken. This must be fixed before continuing with the project, since C is case-sensitive and having lower-case keywords!
    2) Different memories have different methods of programming.
    3) Different memories have different methods of interfacing with the processor.
    4) You are designing - you did select your components based on the information found in datasheets? These datasheets should contain the required information for interfacing and programming the memories.
  • You also have this thread, with the non-descriptive title "regarding source code" (as if not a large percentage of threads on this forum was regarding source code - even if they don't request ready-written code to be handed out):
    http://www.keil.com/forum/19081/
  • I HAVE A PROBLEM FOR WRITING A SOURCE CODE FOR EXTERNAL FLASH
    what flash?
    which chip?
    what is this flash for?
    more words do not make you appeat stupid, they make you appear precise
  • "I HAVE A PROBLEM FOR WRITING A SOURCE CODE FOR EXTERNAL FLASH"
    Apart from an apparent inability to use the CAPS LOCK key correctly, what problem, exactly, do you have?
    Note that, as already stated, 'C' is case-sensitive - so the ability to use the CAPS LOCK key correctly is essential to 'C' programming...
