RL-TCPnet Webserver: Data Download to Client txt-File
I am using the RL-TCPnet Webserver based on the "http_demo" and would like to import and export data into a txt-File on the client pc.
Uploading the data from the client was no problem using the post method to submit the form and process it with the cgi function "cgi_process_data" (as seen in the "http_upload example").
My problem is to export the Data (~1kB) to the Client PC to save it in a txt-File (should be made from the browser).
I am using no file system on the webserver and dont want want to use a tftp server (out of ram and rom).
Shouldn't it be possible to send the Data via HTTP?
I wasn't able to find a library function, nor any examples about this.
Any help would be appreciated!
Thanks in advance,
Mathias
