HI I Use a S3C2440 And K9F2G08U0B. I Modified an Exiting Flash Download Algorithm in keil S3C2440 NAND SP. But It Doesn't Work.When The System Call Function FindBlock(0, 1); then it didn't return From The Function And Went To Address 0x00000000.
#include "..\FlashOS.H" // FlashOS Structures #include "FlashHW.h" // Low level NAND flash declarations #include "NAND_Error.h" // Error definitions #define STACK_SIZE 128 // Stack Size // Enumerated type names definitions enum BOOL_TYPE { FALSE = 0, TRUE}; // Constants values for Small and Large Page const unsigned int BLOCK_SIZE = 131072; // Block size const unsigned int BLOCK_SIZE_SHIFT= 17; // Block size in bit shifts const unsigned int PAGE_SIZE = 2112; // Size of complete page const unsigned int PAGE_USR_SIZE = 2048; // Size of page user data // Global variables used throughout this module unsigned long base_adr; // Base Address unsigned long nand_block_offset; // Offset of valid block unsigned char bus_width; // Bus width unsigned char adr_cycles; // Address word count unsigned char page_type; // Page type (small or large) unsigned int block_size; // Block size unsigned int block_size_shift; // Block size in bit shifts unsigned int page_size; // Size of Complete Page unsigned int page_usr_size; // Size of User Page Data unsigned char data_buf[528]; // Data buffer // Module's local functions prototypes static int FindBlock (unsigned long adr, unsigned int restart); /************************* Flash Algorithm Functions ***************************/ int Init (unsigned long adr, unsigned long clk, unsigned long fnc) { static unsigned char first_run_f = TRUE; if (first_run_f) { first_run_f = 0; base_adr = adr; InitFlashController_HW (&bus_width, &adr_cycles, &page_type, clk); // Remember block size information block_size = BLOCK_SIZE; // Remember block size information in bit shifts block_size_shift = BLOCK_SIZE_SHIFT; // Remember page size information page_size = PAGE_SIZE; // Remember user page size information page_usr_size = PAGE_USR_SIZE; // Restart block searching from beginning FindBlock(0, 1); (*(volatile unsigned long *) (0x56000014))&=0xFFDF; } return (0); } int UnInit (unsigned long fnc) { return (0); } int BlankCheck (unsigned long adr, unsigned long sz, unsigned char pat) { return (1); // Always Force Erase } int EraseSector (unsigned long adr) { if (adr == 0) { // Erasing block for 2-nd level bootloader if (EraseBlock_HW(0) != NAND_OK) return (1); } else { // Erasing block for program FindBlock(adr, 0); if (EraseBlock_HW(nand_block_offset) != NAND_OK) return (1); } return (0); } int ProgramPage (unsigned long adr, unsigned long sz, unsigned char *buf) { unsigned long adr_dest; if (adr < block_size) { // Programming 2-nd level bootloader data adr_dest = adr; } else { // Programming program data FindBlock(adr, 0); adr_dest = nand_block_offset + ((adr-base_adr) & (block_size-1)); } if (ProgramPage_HW(adr_dest, sz, buf) != NAND_OK) return (1); return (0); } unsigned long Verify (unsigned long adr, unsigned long sz, unsigned char *buf) { unsigned long i, adr_dest, in_page_ofs; if (adr < block_size) { // Verifying 2-nd level bootloader data adr_dest = adr; } else { // Verifying program data FindBlock(adr, 0); adr_dest = nand_block_offset + ((adr-base_adr) & (block_size-1)); } in_page_ofs = adr_dest & (page_usr_size-1); if (ReadPage_HW(adr_dest, page_usr_size, data_buf) != NAND_OK) return (1); // Verify if written bytes are same as what was written, if not mark block bad for (i=0; i<sz; i++) if (buf[i] != data_buf[i+in_page_ofs]) { if (adr_dest >= block_size) // Do not mark block 0 as bad MarkBlockBad_HW (nand_block_offset); break; } return (adr+i); } static int FindBlock (unsigned long adr, unsigned int restart) { static int last_src_index = -1; static int src_index; if (restart == 1) { // Just restart for block finding starting from beginning last_src_index = -1; nand_block_offset = 0; return (0); } adr -= base_adr; // Address to relative src_index = adr >> block_size_shift; // Get requested block index for source if (src_index == last_src_index) // Same block as previously requested return (0); while (last_src_index < src_index) { // Find appropriate valid block nand_block_offset += block_size; if (CheckBlock_HW(nand_block_offset) == NAND_OK) last_src_index++; } return (0); }
