Using Keil on Linux Platform
 How to use Keil uVision on ubuntu? Is there any other IDE for ARM processor?
  • What code is that?
    I don't know of any Keil compilers that can compile english directly, so why did you tag your text as code?
    Isn't it up to you to figure out if the Keil tools can be forced into running in any Windows emulation on Ubuntu?
    Did you google? Yes, there are other IDE:s available that can interface with a compiler that can produce ARM code. What results did you get when you tried Google?
