How can I check UVSOCK settings from a batch file?
We use a UVSOCK connection from Matlab. I've set manually a port settings. This has been by my collegue through some updates changed into default values. How can I check "UVSOCK (TCP/IP) Settings->Port setting" from a batch file (windows xp,...)? In Keil IDE I can find it under Edit->Configuration->Other->Port.
Thank you
Richard
