hi,
i want to measure pulse width from 1hz using STM32. would it be possible to use PreScaler. so please provide me some example or link for measuring pulse.
thanks in advance.
The information that you require will be found in the data sheet for the device that you are using.
This information is so useful. Congratulations. You have to be very smart man.
Nathan Duffy is correct: this has nothing to do with Keil!
You need to study the ST documentation, examples, etc
Go to the Product Page for the particular chip you are using - it will list loads of application notes, examples, etc
See also
https://community.st.com/s/
http://www.lmgtfy.com?q=measure+pulse+width+STM32
When looking specifically for source code, Github can be a good place to search ...
The STM32 provides for a PWM Input Capture mode, depending on the model and TIM used, you might need to prescale TIMCLK to get a 16-bit TIM to span 1+ seconds.
The PWM Input Capture pairs two channels (CH1, CH2), and a reset, to provide a tick count for the period and duty of the input signal.
For long duration, and fine granularity of the measurement, consider an STM32 with a 32-bit TIM.
The HAL and SPL should have examples of this mode of operation, for one or more boards within a given part family.
