when i execute dma with irq handler code,irq handler is not executing . insted it goes to statup file end at b. instruction. i obseved that dma irq hadler was not initialised in startup and .c files . can anybody please get rid of this problem thank u
RE:Difficulty debugging ISR issue. ----------------------------------- i got the same problem as above Difficulty debugging ISR issue thread. and i tried those suggestions also,those are not working. it shows that Enable is not a member of NVICstuct. i got other errors, can anybody please send the code for dma with interrupt programme for executing dma irq handler.
