p89lpc936 keil programming help required.
Hello all,
I am trying to program Blinky program from Keil complier to P89LPC936 microcontroller through a universal programmer(SuperPro). But the microcontroller is not running. But when i write a simple program in assambly and program the same hardware it works fine. Please I need help regarding it where i am doing wrong.
Here is code >>>
Code:
/* Blinky.C - LED Flasher for the Keil LPC900 EPM Emulator/Programmer Module */
#include <REG936.H> // register definition
void delay (unsigned long cnt)
{ while (--cnt);
void main()
{ unsigned char i;
P1M1 |= 0x20; P1M2 &= 0xDF;
P2M1 &= 0xE7; P2M2 |= 0x18;
delay (20000); for(;;) { for (i = 0x01; i; i <<= 1) { P2 = i; // simulate running lights delay (20000); } for (i = 0x80; i; i >>= 1) { P2 = i; delay (20000); } }
} Here is Hex file >>>
:10006B008F0B8E0A8D098C08780874FF12004DECEB
:06007B004D4E4F70F32210
:100003004391205392DF53A4E743A5187F207E4EEC
:100013007D007C0012006B7B01EB6013F5A07F2059
:100023007E4E7D007C0012006BEB25E0FB80EA7BBB
:1000330080EB60E3F5A07F207E4E7D007C00120004
:070043006BEBC313FB80EA25
:01004A002293
:04FFF00023001E00CC
:08FFF800000000000000000001
:030000000200817A
:0C00810078FFE4F6D8FD75810B02000347
:10004B007401FF3395E0FEFDFC080808E62FFFF670
:10005B0018E63EFEF618E63DFDF618E63CFCF622E9
:00000001FF
And here is the assembly code and its hex file which is working absolutely right.
Code:
; LPC936A1.A51
; Oct 7, 2010 PCB: ?
; Features: ?
$mod51
RL1 bit P2.3
RL2 bit P2.4
DSEG AT 20H
FLAG1: ds 1
STACK: ds 1
FRL1 bit FLAG1.0 ; Relay 1
CSEG org 0H ajmp Reset
org 30H
Reset: mov 0A5H,#0FFH
Start: mov c,FRL1 ; mov RL1,c cpl c mov FRL1,c mov RL2,c
acall Delay0
ajmp Start
Delay0: mov R7,#250
Delay: mov R6,#61
Delay1: nop nop nop nop nop
nop nop nop djnz R6,Delay1 djnz R7,Delay ret
Text: DB '(C) DIGIPOWER 2010'
Text0: DB ' LPC936A1 '
END
And its hex is
:020000000130CD
:1000300075A5FFA20092A3B3920092A411400133D0
:100040007FFA7E3D0000000000000000DEF6DFF2D7
:10005000222843292044494749504F5745522032CE
:0D006000303130204C5043393336413120CF
:00000001FF
Please help i m stuck.
Regards
Dani
  • Besides forgetting to format your code using the proper tags, you also forgot to mention that you have also posted to:
    www.8052.com/.../179165
    And you forgot to properly markup your code there too.
  • Sir,
    That doesn't relay solves my problem. If you have any answer pertaining to my problem then please tell.
  • That doesn't relay solves my problem
    it might
    very few wants to decipher what is posted forgetting to format your code
  • #include <REG936.H> // Register definition
    // Delay Function----------------------------
    { while (--cnt);
    // Main Function----------------------------
    void main()
    unsigned char i;
    delay (20000); for(;;) { for (i = 0x01; i; i <<= 1) { P2 = i; // simulate running lights delay (20000); } for (i = 0x80; i; i >>= 1) { P2 = i; delay (20000); } } }
    }// main()
    Hex file..
    :01004A002293
    :04FFF00023001E00CC
    :030000000200817A
    :00000001FF
    Code:
    ; LPC936A1.A51
    ; Features: ?
    $mod51
    RL1 bit P2.3
    RL2 bit P2.4
    DSEG AT 20H
    FLAG1: ds 1
    STACK: ds 1
    CSEG org 0H ;ajmp Reset
    org 30H
    Reset: mov 0A5H, #0FFH
    Start: mov c, FRL1 ; mov RL1,c cpl c mov FRL1,c mov RL2,c
    acall Delay0
    ajmp Start
    Delay0:mov R7, #250
    Delay: mov R6, #61
    Delay1:nop nop nop nop nop nop nop nop
    djnz R6, Delay1 djnz R7,Delay ret
    END
    And its hex is
    :020000000130CD
    :00000001FF
    is it better now.. please help me.
  • is it better now.. please help me.
    No, READ THE TEXT ABOVE THE ENTRY WINDOW "place source code ..."
    why have you not answered the questions posted at 8052.com
  • Erik,
    I have tried it too, Even then it is not working. I think i m missing out some step while making the project and its settings which is not creating the hex file correctly. Any idea on this.
    the start900.a51 i have left it to default is it right way to do this.
    Regards
  • I will not continue discussing this in two places, look at 8052.com
    Which was the reason I did cross-link the two threads. However, the OP didn't pick up on the meaning of cross-posting and the havoc and extra work introduced...
