tips on final year project
hello
i have an idea in my mind for my final year project and need some help from you.
we are doing a project in the embedded system field.
we are doing a flood monitoring system using zigbee.this projects will help reduce the water level in flood prone areas using pumps and the communication between the pumps and the control room will be done using zigbee .so please tell me how to get started
  • Divide and conquer.
    Design hardware that detects flooding.
    Implement code that boots processor and prints "hello" to a debug port.
    Extend code to support your flooding sensor.
    Design hardware that controls a pumb.
    Extend code to be able to start and stop the pumps, and also monitors if a pump actually works.
    Design hardware that interfaces the zigbee module.
    Extend code to support that zigbee. Start by sending simple messages and then extend the code.
    Add some hardware and/or other logic for your solution to generate alarms if it thinks something is wrong - flooding sensors not seeming to work, pumps not running when requested to, zigbee communication down, backup power system disconnected or requiring charging or battery replacement, ...
    Of course, backup power may be irrelevant since the pumps will probably require huge amounts of power.
  • The first stage of any such project is the Literature Survey.
    That means that you spend some significant time studying The Literature; ie, papers, reports, theses, etc on this subject.
    That will give you some idea of the current State Of The Art in this field; ie, what others are doing and have discovered.
    That will give you a starting point for your own development...
  • I agree with the posts of Per and Andrew. I take note of the term ZigBee module in Per's post. I recommend that you limit your project to using purchased ZigBee modules at this time. A project even with a large team approach designing and layout of complex RF circuits will be difficult for a school year project.
    Having raised the caution, let me point you to several sources.
    For sub-GHz ZigBee look at the SiLabs products. They have application notes, low cost evaluation modules and software examples.
    For the 2,4GHz range look at the Texas Instruments (ChipCon) products. Again they have many low cost evaluation modules, application notes and software. In this case I suggest that you attempt to stay away from their freeware sofware stacks. Written for th CC25xx series, it is the most vile application of embedded software that has ever been created.
    Just to toggle a LED they go through several levels of pointers/function pointers, enums, structures and macro calls. It's atrocious programming for an 8051 base MCU. It might be fine for C++ programming on their (TI) Code Composer and some DSP but it's junk for the 8051.
    Both companies have application notes for PCB layout including antennas and testing.
    I also suggest that you look at the HART protocol. I know that you have decided or your instructor has decided that you implement ZigBee. HART is in the same RF range (2,4GHz) but a much simpler approach. HART is advertised at 200 meters RF range or more while ZigBee is normally rated less than 75 meters RF range.
    I have used sub-GHz and ZigBee in the same context but I not sure that the sub-GHz radios have been added to the ZigBee compliance protocols.
    There many other vendors of IEEE 802.15.4 radios and software stacks such as Freescale and Ember.
    For documentation start with http://www.zigbee.org. Here is where you will find most of the protocol specification and many more links. Don't get too hung up on meeting the protocols directly unless you plan to interface radios and software from multiple companies. Then strict compliance can be a matter of success or failure.
    Two books I have found most helpful are "ZigBee Wireless Networking" by Drew Gislason - ISBN: 978-0-7506-8597-9 and "ZigBee Wireless Sensor and Control Network" - ISBN: 978-0-713485-4.
    Good luck on your project and remember what Andrew posted. Use the inet to find all types of documentation on Zigbee.
    Al Bradford
  • but don't forget your college Library - that is still an important source of information!
    They may alson have access to databases, academic publications, etc, that are not on the "open" internet...
  • Note that there are several proprietary protocols that use the same basic RF layer as Zigbee.
    In fact, I think that every Zigbee module supplier also has their own proprietary scheme.
    eg, Texas Instruments has their "SimpliciTI" www.ti.com/.../index.htm
    Digi have "DigiMesh" www.digi.com/.../xbee-digimesh-2-4.jsp
    etc, etc,...
  • thanks for the help
    can you recommend some books on zigbee
    if it is flood monitoring system the main center will be located far from the flood prone areas and zigbee having range of 75m .is there a way to communicate with the far away control room without substantial increase in cost
  • What have you found so far?
    How have you decided that Zigbee is appropriate to your task without such materials??
    Start at: http://zigbee.org/
    "is there a way to communicate with the far away control room without substantial increase in cost"
    That's the kind of thing that you'd find as part of your Literature Survey: how have others solved this problem?
    You also need to think about it: what kinds of long-distance communication links can you think of...?
  • The reference to 75 meters for ZigBee and 200 meters for HART was just for comparison between the two. The 75 meters is a reference between two nodes in clear air. As you become more familiar with ZigBee, you will learn of "repeaters" that extend the reporting range far beyond 75 meters.
    Time now to hit the ZigBee books. It has been pointed out twice to start at http://www.zigbee.org.
    Bradford
