Hi !
I have coded 2 interrupts handlers for "time syncronisation app" : _ one is called by TIMER1 expiration to increment sec/msec variables updateClk() _ an other one is called on TTL signal to set sec/msec to arbitrary value (sync) syncClk()
From this link I've seen that these two handlers may execute in parallel which may cause data corruption : www.keil.com/.../rlarm_ar_inter_funct.htm
What I cannot find is : 1) how to check if interrupts nesting is enabled or not and how to disable it. 2) If I can't disable interrupts nesting I though about adding code to disable specific interrupt but does it mean that I would lose the hardware event. For example when executing syncClk() :
I disable TIMER1 MR0 match interrupt update sec/msec var enable TIMER1 MR0 match interrupt
If MR0 MATCH event occured during this process will the interrupt occures when I restore it ? Or do I simply lose it ?
Thanks for response.
I got the answer in the "getting started with RL-ARM". Interrupts are not nested on ARM7/9 architecture, they are for cortex. So I don't need disabling interrupts to avoid data corruption.
I'm still having some doubt about 'interrupt nesting'. From these links :
http://www.keil.com/support/docs/3135.htm http://www.keil.com/support/docs/3353.htm
I understand that LPC23XX can handle interrupt nesting if you implement you're 'it handlers' in a specific way. The "default" code that use 'VICVectAddr' does not allow interrupt handling.
When using RTX, the OS Tick implementation does not allow interrupt nesting. However I don't understand why we associate in some threads "interrupt nesting" and "RTX" as the OS tick has the highest priority and shall never be pre-empted.
