Hello guys!
I'm just starting to use the LPC17xx MCU, using the Keil uVision4 as the design tool. I want to build a new project, using the outstanding CMSIS library, because this is a complete driver library for the MCU peripherals.
After studying the CMSIS included examples, I tried to create a new project, adding all the necessary header and source files of the drivers. (And the Cortex-M driver files too).
I created a simple "main.c" program just for testing the project.
The compiler results of some drivers source files (lpc17xx_gpio.c, lpc17xx_dac.c, etc) show me lots of warnings, but no errors.
And the CMSIS examples, with the same files and structure, compiles without any error.
I just don't know what to do!!!! I think that the problem is in the "lpc17xx_libcfg_default.h" ou the "lpc17xx_libcfg.h" file.
Please, help me.
Regards from Brazil.
---------------------------------------------------------------------------------- Here is the Build Output text result (using just the gpio.c file)
assembling startup_LPC17xx.s... compiling core_cm3.c... compiling system_LPC17xx.c... compiling lpc17xx_gpio.c... ..\..\..\Drivers\source\lpc17xx_gpio.c(293): warning: #188-D: enumerated type mixed with another type ..\..\..\Drivers\source\lpc17xx_gpio.c: return (((LPC_GPIOINT->IO0IntStatR)>>pinNum)& 0x1); ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(295): warning: #188-D: enumerated type mixed with another type ..\..\..\Drivers\source\lpc17xx_gpio.c: return (((LPC_GPIOINT->IO2IntStatR)>>pinNum)& 0x1); ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(297): warning: #188-D: enumerated type mixed with another type ..\..\..\Drivers\source\lpc17xx_gpio.c: return (((LPC_GPIOINT->IO0IntStatF)>>pinNum)& 0x1); ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(299): warning: #188-D: enumerated type mixed with another type ..\..\..\Drivers\source\lpc17xx_gpio.c: return (((LPC_GPIOINT->IO2IntStatF)>>pinNum)& 0x1); ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(617): warning: #186-D: pointless comparison of unsigned integer with zero ..\..\..\Drivers\source\lpc17xx_gpio.c: if ((byteNum >= 0) && (byteNum <= 3)) { ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(623): warning: #186-D: pointless comparison of unsigned integer with zero ..\..\..\Drivers\source\lpc17xx_gpio.c: if ((byteNum >= 0) && (byteNum <= 3)) { ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(655): warning: #186-D: pointless comparison of unsigned integer with zero ..\..\..\Drivers\source\lpc17xx_gpio.c: if ((byteNum >= 0) && (byteNum <= 3)) { ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(661): warning: #186-D: pointless comparison of unsigned integer with zero ..\..\..\Drivers\source\lpc17xx_gpio.c: if ((byteNum >= 0) && (byteNum <= 3)) { ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(687): warning: #186-D: pointless comparison of unsigned integer with zero ..\..\..\Drivers\source\lpc17xx_gpio.c: if ((byteNum >= 0) && (byteNum <= 3)){ ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(712): warning: #186-D: pointless comparison of unsigned integer with zero ..\..\..\Drivers\source\lpc17xx_gpio.c: if ((byteNum >= 0) && (byteNum <= 3)){ ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c(732): warning: #186-D: pointless comparison of unsigned integer with zero ..\..\..\Drivers\source\lpc17xx_gpio.c: if ((byteNum >= 0) && (byteNum <= 3)){ ..\..\..\Drivers\source\lpc17xx_gpio.c: ^ ..\..\..\Drivers\source\lpc17xx_gpio.c: ..\..\..\Drivers\source\lpc17xx_gpio.c: 11 warnings, 0 errors compiling main.c... linking... Program Size: Code=124 RO-data=644 RW-data=0 ZI-data=512 "projeto1.axf" - 0 Error(s), 11 Warning(s).
The NXP CMSIS included examples set the Warnings to "No Warnings".
Check the <Options for Target> -> <C/C++> -> Warnings
