Our application uses multiple target boards (with Luminary Micro Cortex-M3s) interconnected via a CAN bus. We're using a Luminary Micro eval board for programming them individually (with uVision4 via the Stellaris ICDI). However rather than having to move the eval board around when we need to program a different board, is it possible to have multiple eval boards hooked up to the different targets at the same time and have each uVision session use the appropriate eval board? While Windows (7 64-bit) recognizes the eval boards separately, uVision seems unable to tell them apart and just uses the first one plugged in.
