Regarding about
How can i go about calculating the timer values if i want to use the codes below to make the LED blink at 1Hz? How do i do calculation if i want it to blink at different Hz?
// F34x_Blinky.c
// Copyright 2007 Silicon Laboratories, Inc.
// http://www.silabs.com
// Program Description:
// This program flashes the P2.2 green LED on the C8051F34x target board
// five times a second using the interrupt handler for Timer2.
// How To Test:
// 1) Download code to a 'F34x target board
// 2) Run the code and if the P2.2 LED blinks, the code works
// FID: 34X000001
// Target: C8051F34x
// Tool chain: Keil C51 7.50 / Keil EVAL C51
// Command Line: None
// Release 1.1
// -27 SEP 2006 (GP)
// -Fixed #define for SYSCLK from 24.5/8 Mhz to 12/8 Mhz.
// Release 1.0
// -Initial Revision (GP)
// -01 DEC 2005
// Includes
#include <c8051f340.h> // SFR declarations
// 16-bit SFR Definitions for 'F34x
sfr16 TMR2RL = 0xca; // Timer2 reload value(stand for standard film resistor 16 bits)
sfr16 TMR2 = 0xcc; // Timer2 counter
// Global Constants
#define SYSCLK 12000000 / 8 // SYSCLK frequency in Hz
#define BLINK_RATE 10 // Timer2 Interrupts per second
sbit LED1 = P2^2; // LED='1' means ON
// Function Prototypes
void OSCILLATOR_Init (void);
void PORT_Init (void);
void Timer2_Init (int counts);
void Timer2_ISR (void);
// main() Routine
void main (void)
{ PCA0MD &= ~0x40; // WDTE = 0 (clear watchdog timer // enable)
OSCILLATOR_Init (); // Initialize system clock PORT_Init (); // Initialize crossbar and GPIO
Timer2_Init (SYSCLK / 12 / BLINK_RATE); // Init Timer2 to generate // interrupts at a 10Hz rate.
EA = 1; // Enable global interrupts
while (1) {} // Spin forever
// Initialization Subroutines
// OSCILLATOR_Init
// Return Value : None
// Parameters : None
// This function initializes the system clock to (12 Mhz / 8)
{ OSCICN = 0x80; // Configure internal oscillator for // its lowest frequency
//----------------------------------------------------------------------7-------
// PORT_Init
// This function configures the crossbar and GPIO ports.
// P2.2 digital push-pull LED1
{ XBR0 = 0x00; // No digital peripherals selected XBR1 = 0x40; // Enable crossbar and weak pull-ups P2MDOUT |= 0x04; // Enable LED as a push-pull output
// Timer2_Init
// Parameters :
// 1) int counts - calculated Timer overflow rate
// range is postive range of integer: 0 to 32767
// Configure Timer2 to 16-bit auto-reload and generate an interrupt at
// interval specified by <counts> using SYSCLK/48 as its time base.
{ TMR2CN = 0x00; // Stop Timer2; Clear TF2; // Use SYSCLK/12 as timebase CKCON &= ~0x60; // Timer2 clocked based on T2XCLK;
TMR2RL = -counts; // Init reload values TMR2 = 0xffff; // Set to reload immediately ET2 = 1; // Enable Timer2 interrupts TR2 = 1; // Start Timer2
// Interrupt Service Routines
// Timer2_ISR
// This routine changes the state of the LED whenever Timer2 overflows.
void Timer2_ISR (void) interrupt 5
{ TF2H = 0; // Clear Timer2 interrupt flag LED1 = ~LED1; // Change state of LED
// End Of File
