How to Write function in Assemble and interface to C code
Please give some example that will show how write and interface assembly function to C
  • We cannot add inline assembly for ARM cortex M0 ,
    main.c(204): error: #1113: Inline assembler not permitted when generating Thumb code
    below piece of code give error because naked attribute is not in KEIL ARM
    void NMI_Handler(void) __attribute__ (( naked ));
            /* Re-direct interrupt, get handler address from application vector table */
            asm volatile("ldr r0, =0x1008");
            asm volatile("ldr r0, [r0]");
            asm volatile("mov pc, r0");
  • You can use the embedded assembly:
    __asm void NMI_Handler(void)
      ldr r0, =0x1008
      ldr r0, [r0]
    ; mov pc, r0        ; deprecated
      bx  r0
  • Thanks Robert
    I have one more doubt
    As per some document reference that I found on net the expected vector table generated by assembler is give below
    __Vectors       DCD     __initial_sp              ; Top of Stack
                    DCD     Reset_Handler             ; Reset Handler
                    DCD     NMI_Handler               ; NMI Handler
                    [...more vectors...]
    00000000   LDR   PC, =__initial_sp
    00000004   LDR   PC, =Reset_Handler
    00000008   LDR   PC, =NMI_Handler
    but if we see actual code, it will be like
    0x00000000 0268      LSLS     r0,r5,#9
    0x00000002 1000      ASRS     r0,r0,#0
    0x00000004 0169      LSLS     r1,r5,#5
    0x00000006 0000      MOVS     r0,r0
    0x00000008 0171      LSLS     r1,r6,#5
    0x0000000A 0000      MOVS     r0,r0
    0x0000000C 0173      LSLS     r3,r6,#5
    0x0000000E 0000      MOVS     r0,r0
    Any idea where will be the vector table?
  • 00000000   LDR   PC, =__initial_sp
    ---> 4 Bytes
    ---> 2 Bytes
  • Again, the Vector Table contains addresses; not instructions - see your other thread about the Vector Table: http://www.keil.com/forum/19073/
  • What document, exactly?
    Always give a link, so that people can check that it's a good document, and/or that you are correctly interpreting what it says.
    Beware of just implicitly trusting everything you find on the net - always verify it against "official" documentation!
