i don't understand the pin schematics of MCB9B500UME (Fujitsu MB9BF506R). Where are the pins for UART, I2C, and so on?
What is behind the pin naming names?
Thanks a lot!!!
Regards, Torben
You should check the MB9B500 Series Datasheets first.
For example Multi Function Serial 0 (includes UART) has different pins: SIN0_0, SIN0_1, SOT0_0, SOT0_1, SCK0_0, SCK0_1.
Those pin names are also used in the Keil MCB9BF500 schematics. For example SIN0_0 is pin 88 and marked as P21/SIN0_0/INT06_1/BIN1_1 or just N88 at the connector side.
Thanks a lot. This was the information I searched for and I don't found them.
