Please help me on activating CRP for LPC1768 micro using keil uv4.
Regards Zal
On a LPC24xx, you place this
AREA |.ARM.__at_0x01FC|, CODE, READONLY CRP_Key DCD 0x87654321 AREA |.text|, CODE, READONLY
after the interrupt vector. I don't know your chip well just that the CRP codes are the same as many other peripherals etc. I believe this is the construct the compiler will accept for you too but I don't know exactly where to place it in the startup code.
IF :LNOT::DEF:NO_CRP AREA |.ARM.__at_0x02FC|, CODE, READONLY CRP_Key DCD 0xFFFFFFFF ENDIF
The above is copied from startup_LPC17xx.s (NXP's code.bundle.lpc17xx.keil). So, I believe that, you can find the CRP_Key setting in the KEIL startup.s for LPC17xx.
John,
The OP was interested in ENABLING CRP. Your code snippet does not;
It should have been
CRP_Key DCD 0x12345678
for CRP1, or
for CRP2 or
CRP_Key DCD 0x43218765
for CRP3.
Hi Tamir,
I remember that you have already start the real development on LPC17xx Cortex-M3. Do you use the new programming model? I mean the Software Driver Model.
lpc17xx.cmsis.driver.library.zip:
ics.nxp.com/.../code.bundle.lpc17xx.keil.zip
More and more documentation need to be read, I am a little frustrated.
I only wrote 2 small bootloader for this chip so I don't know it too well - still working with LPC2478. But once we start with the C model (we still did not start with B though...) - I will ! Thanks for the link.
