Hi there,
I am using UV4 from the command line as such:
> UV4.exe -b myproj.uvproj
and this works fine, the build completes and returns "0"
However, whenever I use the same to try and build an uvmpw file:
> UV4.exe -b mympw.uvmpw
the return code when the process exits is "1" instead of "0" even if the build runs successfully. This prevents me from integrating the command line with make-like tools (msbuild) since those check for the return value to know whether the compiler invokation was successful.
Is there a reason I am getting a "1" as a return code when the process exits?
Regards,
Carles
... that you expect warnings to be "build runs successfully"
Indeed I expect warnings to be just that, warnings, but just as with most toolchains (gcc + make for example) they should not compromise the integrity of the build, and hence the return code should be 0. I will check if the warnings are the cause though.
of a return code of 1 for warnings and 2 for errors. i do believe this is Keil, but could be another compiler.
try provoking an error and see what you get
"I will check if the warnings are the cause"
Don't you think that you should have checked that first?!
http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm
Fair enough, apologies, I must've missed that while reading the doc.
Thanks for the feedback.
