ID string in a flash
I need to put an ID string (file name and version) at a particular address in a flash, so the programming application can read it from a hex / binary file.
I can probably use a scatter file, but is there any simpler solution ?
Cortex-M3 STM32F107
MDK-ARM 4.12
thank you,
Gennady
  • Hi Gennady
    const char string[] __attribute__((at(0x0xxxxxxx)) = "Version 1.xxxxdfdf";
    willi
  • Thank you Willi,
    well, now I have another question.
    Is there any way to put this string at the end of a program flash used ?
    I have some considerations where it will be more beneficial to have it at the end instead of a fixed address.
    Gennady
  • I normally place some meta data (such as crc, version info etc) in last bytes of flash. But if I place the information in the last 16 bytes, that is still at a fixed position. I might decide to have the normal build place 12 byte of info at the end, but leave the last four byte. Then run a post-process program that computes CRC32 and fills the last four bytes with the CRC of the image.
  • Actually that is exactly what I need (except that post-processing app will write a program size along with checksum there).
    So the question is still the same - how do I make a build to place this metadata array at the end of a program ?
  • I tried to follow the procedure suggested by Pontus Thuvesson in
    http://www.keil.com/forum/docs/thread16466.asp
    That is what I did:
    in a main:
    #pragma arm section rodata = "codeEnd"
    const uint8_t metadata[19] = {'J','0','0','_','1,'1',1, 3,57,0x08,0x00,0x00,0x00,0x44,0x44,0x44,0x44,0x55};
    then I edited the scatter file to this:
    ; *** Scatter-Loading Description File generated by uVision ***
    LR_IROM1 0x08000000 0x00020000  {    ; load region size_region
      ER_IROM1 0x08000000 0x00020000  {  ; load address = execution address
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
       *.o(codeEnd, +Last)
      RW_IRAM1 0x20000000 0x0000C000  {  ; RW data
       .ANY (+RW +ZI)
    and unchecked 'used memory layout from a target dialog'.
    Nevertheless the metadata[] array does not appear at the end of a program. Is there anything i did wrong ? or haven't done ?
  • I am still trying to get rid of extra data appearing at the end of an image after my string.
    According to http://www.keil.com/support/docs/3512.htm
    these is compressed RW initialization data.
    According to the difference between sizes of Load Region LR_IROM1 and Execution Region ER_IROM1 in a memory map, amount of these data is 124 bytes. I actually have 125, but maybe I miscalculated something.
    Anyway, all attempts to eliminate these data were unsuccessful. I tried adding --datacompressor=off in a linker options, some other staff - no luck.
    While doing extensive research on a forum, I saw quite a few references to 'putting metadata / special data at the very end of a rom image'. So it seems like there is a lot of expertise on this issue.
    Please, could someone point me in a right direction.
    Gennady
  • I think that what your wanting is similar to what I described in:
    http://www.keil.com/forum/docs/thread16898.asp
    Unfortunately, I found/got no solution.
  • How about this?
       *.o (RESET, +First)
       *(InRoot$Sections)
       .ANY (+RO)
       .ANY (+RW +ZI)
    LR_IROM2 +0 {
      ER_IROM2 +0  {
       *.o(codeEnd, +Last)
  • Mike, thank you so much !
    It works, and I see how you've done it.
    Beautiful.
    Gennady
