Howdee
I'm trying to create a UART Debug Function in which i can pass it some parameters 1 of them a string or array of data I've tried then following but none of them work
FUNC void UARTinput(unsigned char CMD, unsigned char DATA[]) { ... }
FUNC void UARTinput(unsigned char CMD, unsigned char DATA[255]) { ... }
The idea is to run the Debug Function as follows: UARTinput( 0x34, 'HELLO WORLD')
In what way, exactly, do they "not work"?
You have made two silly mistakes in your post:
1. You didn't follow the instructions on how to post source code;
2. The 'C' language does not use single quotes for strings
So the chances are high that the problem is due to a "silly mistake" somewhere in your code - but only you have the code, so only you can find it!
The second point is a mistake which i know i should have placed the Double quotes for a string... sorry about that.
The problem is the variable "DATA"
When I compile using the Function Editor (in Debug Mode) it gives me an Error "Syntax error" which is not accepting the variable
OR
is there another moethod of declaring a string for the Debugger scripting language.
Arrays, structures and pointers are not allowed. This is stated in the documentation.
Drats thats dissapointing...
Thanx Jakob
Nonsense!
"This is stated in the documentation"
Where??
Post a link to where it says that!
No - it's just wrong!
Keil tools certainly do support pointers & arrays & structures!
What happens if you use a name other than DATA...?
And you're sure that applies to debugger functions too?
Ah - no.
I totally missed that!
>blush<
Yes that is one of the restrictions of uVision Debug Functions - see: http://www.keil.com/support/man/docs/uv4/uv4_df_diffbtwdbgandc.htm (5th bullet point).
My mistake.
Andy here it is stated in the debug language documentation, oddly I was using the simulator the last few weeks to find an obscure bug anyhow I happened to know for a change:
PS is the op sure it was a C251 he was working with? I haven't written anything for that thing for 8 years.
Stephen
