Hello! In my project in Keil i am using mixing programming C and ASM with working inline assembler. I have some problems to access variable define in asm from C.
I define variable in module spi (spi.src file)
NAME SPI ?DT?spi_vars?SPI SEGMENT DATA PUBLIC ADC1H,ADC1L,DAC2H,DAC2L RSEG ?DT?spi_vars?SPI ADC1H DATA 0x32 ADC1L DATA 0x33 DAC2H DATA 0x34 DAC2L DATA 0x35 ?BT?spi_bit_vars?SPI SEGMENT BIT PUBLIC SPI_num RSEG ?BT?spi_bit_vars?SPI SPI_num BIT0x24.1
and define this variable using C (file main.h included in main.c)
extern data unsigned char DAC2H; extern data unsigned char DAC2L; extern data unsigned char ADC1H; extern data unsigned char ADC1L; extern bit SPI_num;
But when i try using this variable i get error
main.src(250): error A45: UNDEFINED SYMBOL
Also i try using inline assembler in my main.c file
EXTRN DATA (DAC2H,DAC2L,ADC1H,ADC1L) EXTRN BIT (SPI_num)
but get error:
CLASSES (XDATA (X:0x0-X:0x7FF), HDATA (X:0x0-X:0x7FF), CODE (C:0x0-C:0x7FFF), CONST (C:0x0-C:0x7FFF), ECODE (C:0x0-C:0x7FFF), HCONST (C:0x0-C:0x7FFF)) *** ERROR L220: INVALID INPUT MODULE MODULE: main.obj (MAIN)
question : How to correct access to assembler variable fro C with working inlin assembler or without.
. I am partially solved this problem i am add absolute location on my variable defined example
extern data unsigned char DAC2H _at_ 0x32; extern data unsigned char DAC2L.......; extern data unsigned char ADC1H.......; extern data unsigned char ADC1L.......; extern bit SPI_num;!!!!!!!!!!!
but no solve problem with SPI_num, becouse _at_ no implemented for bit variable in C51. maybe who knows how sole this problem???
Thanks!!
